2^32
I was just wondering why the Prop can't calculate 2^32.
Answer should be 4,294,967,296
Gary Lake
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ pst : "Parallax Serial Terminal" var long t long i PUB main pst.Start(115_200) i := 2 t:=0 repeat 32 t++ pst.Dec(t) pst.tab pst.Dec(i) pst.newline i := i *2 pst.Str(string("All done!"))Terminal window print out.
1 2 2 4 3 8 4 16 5 32 6 64 7 128 8 256 9 512 10 1024 11 2048 12 4096 13 8192 14 16384 15 32768 16 65536 17 131072 18 262144 19 524288 20 1048576 21 2097152 22 4194304 23 8388608 24 16777216 25 33554432 26 67108864 27 134217728 28 268435456 29 536870912 30 1073741824 31 -2147483648 32 0 All done!
Gary Lake
In binary the answer is
1_00000000_00000000_00000000_00000000
which is why you are getting zero. There will be an overflow flag somewhere.
Something like -- PHS bit 31 frequency = 80_000_000 x 322_122_547 / 2^32
A ** B = A* B / 2^32. Basically, it does multiplication of two 32-bit numbers into 64-bit number, and returns the higher 32 of those 64 bits
Something like -- PHS bit 31 frequency = 40_000_000 x 322_122_547 / 2^31
Duane
The A**B worked and the answer was 5,999,999
