Help with NES controller programming.
My students and I are working on a tethered robot. We are new, and relativley inexperienced with programming and are having difficuluty with designing a program to control a Boe Bot using the NES controller. We have successfully tested the NES and a controller and it is in working order. (RLDUTEBA) are all working correctly. Where we are confused is in developing the programming language that would allow us to control the robot. How/what commands are used to identify the control inputs once the program is working? Could someone please provide a bit of sample programming for us to study and jump off from?
thank you for any assistance.
PULSOUT 5, 10 ' latch data
SHIFTIN 6, 4, LSBPRE, [value(0) \8] ' shiftin socket1
So, you end up with input/NES data placed in the variable called "value(0)"
Instead of DEBUGing that, or in addition to that, you'd make a decision
about what to do given that data, e.g.:
IF value(0) = %11101111 THEN Move_Forward ' U was pushed
Move_Forward, a subroutine, could turn on a motor for a brief period,
to go forward a brief period, and then the program would check for
new NES data.
