PIR sensor period
I noticed that once the PIR sensor is triggered it takes a while for it to go back to a low state. The period is about 2 seconds and I was wondering if there is anyway to decrease the period of the PIR sensor after it is triggered or to force it to a low?
That delay is fixed in the innards of the module. The only thing you can change is the supply voltage and that has seemingly no effect on the output pulse. :blank:
You would have to use some sort of external circuitry to develop a signal of shorter duration.
Amanda
