Voltage fault on Demo board
I got a propeller chip demo board. Currently doing an internship, so still learning. The problem is when I plug it in, do not get the correct voltage at the regulators. With a 9V input, I get 2.6V after the first VReg and 2.3V after the last. When I reduce the input to 4.5V I get 4.3V after the first and 2.8 after the second. Thus the output is inversely proportionate to the input. What can cause this?
Is the power supply good and solid. If that was unstable then all sorts of lies could be told on your meter.
Welcome to the Prop, people will turn cartwheels, here, to help.
The outputs with your 4.5V supply could be right, BTW. Every linear regulator has a "drop out" voltage. This is the voltage which must be added to the output voltage to yield the minimum input voltage. From your figures the 5V regulator appears to have a 0.2V dropout; the 3.3V regulator, 1.5V. So you need at least 5.2V on the input -- preferably at least 6V.
