Help with simultaneous control of 2 stepper motors using Propeller
What I basically aim to do is to control many (4 in total) stepper motors SIMULTANEOUSLY using the propeller. I wrote an object that successfully controls 1 stepper motor, but when I try to launch the object multiple times, it doesn't work!
This is the code of the object:
Right now all it excecutes is what "stepper.Start(19,22, 200, 0)" does. I suspect that for some reason when I try to launch a second cog, I stop the previous one.
Thanks in advance!
-kotsos
_xinfreq = 5_000_000
_clkmode = xtal1 + pll1x
DAT
Steps byte %1100, %0110, %0011, %1001
VAR
long cntr, stpIdx
long stack[200]
byte cog
PUB Start(P1, P4, nxt, prev) : success
Stop
success := (cog := cognew(gostep(P1, P4, nxt, prev), @stack)+1)
PUB Stop
if cog
cogstop(cog~ -1)
PUB gostep(P1, P4, nxt, prev)
dira[19..22]~~
outa[19..22]~~
dira[28..31]~~
outa[28..31]~~
if prev < nxt
stepFwd(P1,P4,(nxt-prev))
elseif prev > nxt
stepBwd(P1,P4,(prev-nxt))
PUB stepFwd(P1,P4,stps)
repeat cntr from 1 to stps
stpIdx := ++stpIdx // 4
outa[P1..P4] := Steps[stpIdx]
waitcnt(clkfreq/200 + cnt)
PUB stepBwd(P1,P4,stps)
stpIdx := (stpIdx + 3) // 4
This is the script that calls the object:
VAR
long cntr, stpIdx
OBJ
stepper : "Stepper_motor_trials"
PUB launchStepper
stepper.Start(28,31, 200, 0)
Any suggestions on how to launch the object "stepper" on multiple cogs?Right now all it excecutes is what "stepper.Start(19,22, 200, 0)" does. I suspect that for some reason when I try to launch a second cog, I stop the previous one.
Thanks in advance!
-kotsos
_xinfreq = 5_000_000 _clkmode = xtal1 + pll1x VAR long cntr, stpIdx OBJ stepper[COLOR="red"][2][/COLOR] : "Stepper_motor_trials" PUB launchStepper stepper[COLOR="red"][0][/COLOR].Start(28,31, 200, 0) stepper[COLOR="red"][1][/COLOR].Start(19,22, 200, 0)You do need two instances of the same object. Previously you simply re-started the one stepper object you had. Also, the hardwired dira/outa assignments in the gostep method look suspicious.Still nothing moves.
How do I clean the gostep method, as you mentioned?
Thanks!
I got it!!!
I re-corrected the dira/outa thing. Here is the code:
_xinfreq = 5_000_000 _clkmode = xtal1 + pll1x DAT Steps byte %1100, %0110, %0011, %1001 VAR long cntr, stpIdx long stack[200] byte cog PUB Start(P1, P4, nxt, prev) : success Stop success := (cog := cognew(gostep(P1, P4, nxt, prev), @stack)+1) PUB Stop if cog cogstop(cog~ -1) PUB gostep(P1, P4, nxt, prev) dira[P1..P4]~~ outa[P1..P4]~~ if prev < nxt stepFwd(P1,P4,(nxt-prev)) elseif prev > nxt stepBwd(P1,P4,(prev-nxt)) PUB stepFwd(P1,P4,stps) repeat cntr from 1 to stps stpIdx := ++stpIdx // 4 outa[P1..P4] := Steps[stpIdx] waitcnt(clkfreq/200 + cnt) PUB stepBwd(P1,P4,stps) repeat cntr from 1 to stps stpIdx := (stpIdx + 3) // 4 outa[P1..P4] := Steps[stpIdx] waitcnt(clkfreq/200 + cnt)And
Thanks A lot! You solved my problem!!!!!
