SDcard fsrw26 err -1000
AS
Hello!
I need big help!!
I try use obj fsrw26:
If no card I have the error "-1" (as expected)
With the card I have the error "-1000" (why?)
thanks to all that try help!
Andrei Sousa
I need big help!!
Andrei Sousa
if( (cnt - SPI_block_index) > (clkfreq << 2) ) crash( ERR_CARD_BUSY_TIMEOUT )That sets the timeout to 4 seconds. If you want to try a much longer timeout, just to see if this card is very slow, change to "(clkfreq << 4)" to make it wait 16 seconds.Can you try this code with another SD card? Is it possible there are problems with the electrical connections, mixing up pins, etc.?
Jonathan
The error of timeout is because the old SDcard, with a new one I have the error -1
The pins are not mixed up, i already see hundred times!! :P
I was looking with a voltimeter all the pins:
WP - 0V (if no protect SDcard to Write)
CD - 0V (if card inside)
IRQ - 3.3V
DO - 2.2v (IS NORMAL?) (to P0)
SCLK - 3.3v (to P1)
DI - 3.3V (to P2)
CS - 3.3V (to P3)
RW - 3.3V
with the obj "fsrw-and-friends-1.7" i have the error "-13"...
any suggestion is welcome!
Andrei Sousa
