Spin Pop Quiz, what's wrong with the SetPosition method.
The SetPosition method in the code below contains the same bug in two places. Can you spot it? I felt pretty silly when I finally did.
I'll check back later and see if anyone got it. I'll also post the corrected code in case no one does.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
' Angular values for common angles
RIGHT_ANGLE = pi / 2.0
STRAIGHT_ANGLE = pi
FULL_ROTATION = 2.0 * pi
' Arm dimensions in mm
BASE_HGT = 95 ' base hight 3.75"
HUMERUS = 133 ' shoulder-to-elbow "bone" 5.25"
ULNA = 157 ' elbow-to-wrist "bone" 6 3/16"
GRIPPER = 127 ' gripper (incl. wrist rotate mechanism) length 5"
' Servo names and pin assignments.
BASE_SERVO = 0
SHOL_SERVO = 1
ELBO_SERVO = 2
WRIS_SERVO = 4
WROT_SERVO = 5
GRIP_SERVO = 6
' pre-calculations for right triangle trig.
HUME_SQ = HUMERUS * HUMERUS
ULNA_SQ = ULNA * ULNA
OBJ
f32 : "F32"
fs : "FloatString"
pst : "Parallax Serial Terminal"
servo : "Servo32v7.spin"
VAR
' Coordinates in arm polar space.
long m_baseAngleRads
long m_sholAngleRads
long m_elboAngleRads
long m_wrisAngleRads
long m_wrisRotAngleRads
' Coordinate of gripper tip in cartesian space.
long m_x
long m_y
long m_z
long m_wrisGroundAngleRads
' Start and Stop methods removed for brevity as they aren't the problem.
PUB SetPosition(x, y, z, wristAngle) | grip_off_y, grip_off_z, wrist_y, wrist_z, s_w, s_w_sqrt, a1, a2, elb_angle_rn
SetPosition : Arm positioning routine utilizing inverse kinematics. Since the arm is
resting on a surface Z can only be positive. Servo movement contraints prevent y
from being negative, But X can be a signed value.
Parameters:
x integer side to side displacement.
y integer distance out from the base center.
z integer height above the table
wristAngle wrist angle of the gripper in radians.
' Save the cartesian space coordinates.
m_x := x
m_y := y
m_z := z
m_wrisGroundAngleRads := wristAngle
' Convert x and y to float and compute a polar angle to position the base.
SetBase(f32.ATan2(f32.FFloat(x), f32.FFloat(y)))
' Compute the vector magnitude and hold in the y coordinate.
y := ^^((x * x) + (y * y))
' Convert gripper length to float and use for Gripper offsets calculated
' based on grip angle and convert back to integer with rounding.
grip_off_z := f32.FRound(f32.FMul(f32.Sin(wristAngle), FLOAT(GRIPPER)))
grip_off_y := f32.FRound(f32.FMul(f32.Cos(wristAngle), FLOAT(GRIPPER)))
' Wrist position
wrist_z := (z - grip_off_z) - BASE_HGT
wrist_y := y - grip_off_y
' Shoulder to wrist distance is a hypotenuse ( AKA sw )
s_w := (wrist_z * wrist_z) + (wrist_y * wrist_y)
s_w_sqrt := ^^ s_w
' s_w angle to ground
a1 := f32.ATan2(f32.FFloat(wrist_z), f32.FFloat(wrist_y))
' s_w angle to humerus
a2 := f32.ACos(f32.FFloat( ((HUME_SQ - ULNA_SQ) + s_w) / (2 * HUMERUS * s_w_sqrt) ))
' Position servo to shoulder angle and set the shoulder data member
SetShoulder(f32.FAdd(a1, a2))
' Position servo to elbow angle and set the elbow data member.
SetElbow(f32.ACos(f32.FFloat((HUME_SQ + ULNA_SQ - s_w) / (2 * HUMERUS * ULNA))))
elb_angle_rn := f32.FNeg(f32.FSub(STRAIGHT_ANGLE, m_elboAngleRads))
' wrist angle
SetWristAngle(f32.FSub(f32.FSub(wristAngle, elb_angle_rn), m_sholAngleRads))
' Set methods removed for brevity as they aren't the problem.
a2 := f32.ACos( f32.FDiv( f32.FFloat((HUME_SQ - ULNA_SQ) + s_w), f32.FFloat(2 * HUMERUS * s_w_sqrt) ) )
The second one needed the same fix. A real groaner when I found it.
