Here is a 5 volt @ 700 millamp switching power supply are Gone at GoldMine Electroni
http://www.goldmine-elec-products.com/prodinfo.asp?number=G17395 They were $0.79
One note about this (you can cut off connector if you desire). you can open the the connector that at the end of the cord it has two screws to open it then you do not need to cut any thing off
I am using this to power my Propeller Education Kit that I put on a Proto Board
"Small lightweight charger made by Samsung part# ATADM10JBE has standard plug for AC outlet and special connector on other end. Cut off the connector and you have a nice lightweight charger/adapter capable of putting out regulated 5VDC at up to 700mA. Size of adapter body only 2.3" x 1.1" x 1.4". Can operate from 100VAC up to 240VAC. New in sealed bag (you can cut off connector if you desire). Reg $2.29 each. G17395 "
That's a good find... I have re-purposed a couple of our own cell-phone chargers in a similar way. By the connector in your link, it looks like that's what the power supply was originally intended for. A few that I have used are rated at 5V 500mA.
That not the bigger problem
Here is the real problem and that is this that the Switching Power Supply dose not over current I seen a few them do this and had to use a LM317 to control them
I have seen a few over current at least 500 millamps over what they are rated at
http://www.allelectronics.com/make-a-store/item/PS-10/1-AMP-SWITCHING-POWER-SUPPLY-w/SELECTABLE-OUTPUT//1.html
Here is an example of one that I just hacked to charge lithium cell 8.4 volt battery pack when set to 8.4 volts It was charging at 1.47 amps and is only rated at 1 amp
I will have to run one in a over current state and see what happen to it and see how long it will run that way before it shut down and if it work again once it cool down
BTW this power supply has 1 amp MAX on it the one I was talking about
http://www.allelectronics.com/make-a-store/category/480/Power-Supplies/1.html
http://www.goldmine-elec-products.com/products.asp?dept=1007
I hope this helps
