Basic Stamp Programming Techniques — Parallax Forums
siuchumingsiuchuming Posts: 2
edited 2011-03-20 05:38 in BASIC Stamp
2. Display the message “ Please Key in S to start ” in the Debug Terminal and prompt the
user to key in letter S. Display the message “ Wrong letter ” in the Debug Terminal
and prompt the user to key in again when the input is not S. If the input is True , then
display the message “ Right letter ” in the Debug Terminal.
3. Display the message “ Please Key a number (1 to 9) ” in the Debug Terminal and
prompt the user to key in. Display the message “ Number out of range ” in the Debug
Terminal and prompt the user to key in again when the input is less than 1 or larger than
9. If the input is True, then display the message “ Right Number ” in the Debug
Terminal.
4. Turn on two LEDs at P4 and P7 respectively and make a time delay ( 1 second ). Turn
on the buzzer for 0.5 second with two frequencies mixed. The two frequencies are
2500 and 3000 respectively, at P12 of the IVE StampBot. Make a time delay ( 2
second ). Turn off two LEDs at P4 and P7 respectively and make a time delay ( 1
second ).
5. Turn on two LEDs at P5 and P6 respectively and make a time delay ( 1 second ). Turn
on the motors of the IVE StampBot to make it turn around (either clockwise or
anti-clockwise) and then make a time delay ( 2 second ). Turn off the IVE StampBot
and then make a time delay ( 2 second). Turn off two LEDs at P5 and P6 respectively
6. Display the message “Please Key in any number from 1 to 9 to make a LEDs.
On-Off pattern” in the Debug Terminal and prompt the user to key in a number. If the
input is True , then make a Subroutine called “PATTERN”. Use the input number as
the LEDs On-Off pattern to turn on the corresponding LEDs and then make a time delay
( 2 seconds ). Repeat step 1.
HELP ME...I don't know how to do these five questions.Plz help me...
    edited 2011-03-19 23:34
    All of the answers are in the Teacher's manual.
    They are also in "What's a Microcontroller", which is somewhat easier to get, but unfortunately you'll have to (UGH) read, think, and achieve.
  • siuchumingsiuchuming Posts: 2
    I want to get answers...Tomorrow have a test T^T"
