Propeller Proto Board wiring question — Parallax Forums
SSteveSSteve Posts: 808
edited 2011-03-16 22:54 in Propeller 1
Am I correct in interpreting the PPB schematic that the holes I've circled are connected through 10k resistors to 3.3V? (My hardware skills are effectively non-existent.)
239 x 139 - 27K
  • JLockeJLocke Posts: 354
    edited 2011-03-16 18:39
    It looks like you are supposed to install 100-ohm resistors in the left-most two holes (the ones you have circled and the holes immediately to the right of those). I'm basing this on the instructions on the top of page 4 of the Propeller Proto Board Manual. It appears these are only used if you are utilizing the PS/2 option(s); they are marked 'Optional' on the schematic.
    So I guess to answer your question, yes, one of those holes is pulled-up to 3.3V through 10K. I don't have a Proto Board in front of me to verify that it is the left-most hole that is pulled-up, but you should be able to trace it out on the board or with a voltmeter. The other side of the pair will connect back to pins P24-P27 on the propeller.
    edited 2011-03-16 18:55
    Yes, the 4 left hand holes are connections to the Mouse/Keyboard Pullups. They are circled in the attachment.
    SSteve wrote: »
  • SSteveSSteve Posts: 808
    That's great. My project has a couple buttons and those 10k resistors will be perfect for the pullups. Thanks for your help.
