Humidity Sensor HS1101
I have just installed the HS1101 and the Relative Humidity at the debug terminal reads 11%.
Present weather outside is overcast, rain and quite humid. Would a change in resistors 220ohm
and 10M ohm give a more realistic reading?
sparks5
sparks5
Since the HS1101 is essentially a capacitive cell, some calibration may need to be done in different operating environments. You shouldn't need to change the resistor values, as the 10 M-ohm resistor was chosen based on the sensor's nominal capacitance.
You can find calibration information in the HS1101's product documentation.
Or, check out the datasheet for additional wiring options.
Either way, let us know if you have any other questions!
Cheers,
Jessica
Thanks for the reply, the sensor is indoors. Reducing the RHconstant increases the RH or leaving the RHconstant alone and dividing the equation by 6 increases the RH from 12% to 56% which is more
realistic. I guess I will have to borrow a hygrometer to calibrate the sensor more accurately.
Maybe Jessica can let me know where the RHconstant figure 12169 comes from and what am I doing when I alter that figure and the division figure.
p.s. Jessica I enjoyed your Christmas Caroling
You never mentioned which chip you are using with the sensor. The R/c time can vary with different MCU's.
Quote from:
http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/27920-HS1101-v1.0.pdf
