Whats the most Stable HTTP Server currently?
Hi All,
I have been working on some other things, and would like to get back at my spinneret....
Currently which is the most stable and feature filled (Get/Post) Http Server??
I understand everything is a work in progress, stability/reliability would be the most important to me.
Rick
Rick
I've been using "Spinneret Web Server DEMO v1.2" and it's rock solid on my LAN. It worked fine with LEDs and also servos. For slower connections with higher latency, the only time I notice it locks up is when you send it commands too quickly which I've been messing around with quite a bit. I think if you launch the routine that is triggered by the POST data in a new cog it becomes even more stable. I haven't done that yet because like I said it's very stable on my LAN.
Check the collaborative projects section it's all in there.
