Need your input on multi-cog LED demo
Ok gang.. I need some input..
Everyone know I'm keen on writing tutorials and helps for new users..
Ever have one of those mental blocks when writing something?
One of the items I'm working on is a short demo of multi-cog ability of the Propeller.
In this demo, I've got some LEDs at my disposal and I'm aware of the little mutli-led demo that was part of the PEkit.
Here is where you come in...
There has got to be a method to demonstrate this ability with LEDs other than simply flashing them in different times. (Boring!) Something "simple" and with "appeal".
I've been working on a multi-candle sim, but I'll bet there is more...
OBC
OBC
OBC
http://www.nbtv.org/ The had 28 or 30 verticle lines and I think ther were som sets that were two-way like a video phone.
http://www.earlytelevision.org/mechanical.html
You could use a rotating wheel with 30 or 32 holes to make one of these. I wonder if a color sensor would be fast enough to make such a TV with a tri-color output led to display the video.
At least you could use a photo diode to make a B/W version/
OBC
It runs on a DemoBoard, launches a PWM function on all 8 cogs with different period values. Each cog runs the PWM loop while cycling the duty value up & down, resulting in the LEDs all pulsing at slightly different frequencies. It kind of looks like really small Christmas tree lights.
Paul
You could build the scanning disk with retroreflective tape instead of holes. Place the disc at the back of a box using a fan motor take from an old computer. At the front of the box use one of those credit card size magnifiers ( fresnel lens). A red LED next to the fresnel lens would provide similar displays to the original neon, but it is easy to obtain white LEDs these days . A photo diode next to the fresnel lenst would allow you to capture images.
It should be relatively easy to make a 32 line display, put possibly 48 of 64 lines could be achievable. Leave out one of the reflectors to provide a blank space for synchronization.
Transmit with a stereo (one channel is audio, other is video). One of the cheap car radio FM broadcasters could provide the transmission capability's.
Gee! I should be making this.
Perry
