Need help with Propeller Backpack Example Code
Hi folks (and Phil)
I am starting to program my Backpack and am using the Overlay demo code to understand all of th flags etc.
I have run into an understanding issue with this line
Defwin, 10, 40, DBL|2, $f, 0, 8|TPT,1
Now I can understand as far as Create a Windows #10 with 40 columns Double Height but then the rest fails me. I have read through the documents but the DefWin does not have that many options. So I am wondering what the rest are doing
Any explanation greatly appreciated.
Dave
Dave
Does it make more sense now? If not, let me know, and we can discuss it further.
Unfortunately it got lost in the PBasic to PicAxe conversion
Many many thanks for that.
Dave
I am trying to format a screen on the Prop Backback and I am not sure if it is possible. I am puzzle re the horizontal window placement
I have 2 windows for lists. One will list information down the left hand side of the screen and the other doen the right hand side.
No matter what I seem to do with the APNDSP, or the MOVWIN commands I just cannot get them to be side by side. Neither window is overlapping the other and there shoud be plenty of space between them.
Many thanks
Dave
I did read that, just needed to clarify it re what I am trying to do, and wether there was any other way to approach the task i.e. Defining a window and then moving it into position etc.
Likewise I can see no way to bold/reverse a single character to highlight it as all operations are on a window level too i.e.
[HTML]
<TABLE>
<TR><TD>
STATUS
</TD><TD> ----COMMANDS----</TD></TR>
<TR><TD>X-Axis </TD><TD>12345.67 </TD><TD>LEFT </TD><TD>Act-Left</TD></TR>
<TR><TD>Y-Axis </TD><TD>5676543 </TD><TD>RIGHT </TD><TD>Act-Right</TD></TR>
<TR><TD>LAT </TD><TD>12345.678</TD></TR>
<TR><TD>LONG </TD><TD>135324</TD></TR>
</TABLE>
[/HTML]
Sorry - no way to format tables in this editor.
Just checking.
Many thanks for your help and advice. It really is greatly appreciated.
Dave
One way I can see around the formatting issue is to modify the character set. If the characters used are the same as in the terminal version of the code then I could use some of them and do a reverse bit image. That way the Prop would not be asked to do any extra work.
At least we are working with a monospaced font (unlike this editor) so I could write out the table format by character positioning.
Many many thanks for your help Phil.
Take Care
Dave
After looking through all of the Spin code supplied with the Prop Backback I could not find the Character set used.
Is it in the Spin code or is it in another location that is accessable by a developer (Firmware etc)
Many thanks
Dave
