General Design Question - Capacitor Selection
Could you guys chime in with your knowledge of what type of capacitor to use when? It seems each type of capacitor has its own strengths and weaknesses. I'll share what I know to get the ball rolling, but I think this would be very useful for MANY people who roll their own boards and do their own designs. As you guys post I'll go back and edit this post so it can useful to people in the future as an easy reference
Categories of Capacitor Usage
* Signal Level Filtering
** Mylar Film
* Mains Filtering
* DC Power Supply Filtering
** Tantalum for <= 1uF
** Electrolytic for >1uF
* Fast Bypass
** Tantalum
* Bypass Reservoir
** Electrolytic
* Super-caps / Battery Replacement
** Aerogel
* Bipolar
** Ceramic
** Bipolar Electrolytic
Specs
* Temperature Ranges
* Voltage spikes outside the cap's voltage ratings
* Bipolar vs. Polar Caps
* Low ESR vs ...
Availability in Surface Mount
Price Effective in Surface Mount
** Mylar Film
* Mains Filtering
* Fast Bypass
** Tantalum
* Bypass Reservoir
** Electrolytic
** Aerogel
* Bipolar
** Ceramic
Specs
* Low ESR vs ...
Up to 47uF I always go with Ceramic type in X5R or X7R due to low ESR.
Plus I don't have no worry about mounting them in reverse by mistake.
http://www.mouser.com/ProductDetail/TDK/C3225X5R0J226K/?qs=sGAEpiMZZMvQvaS66kI3TnE1JaRpwCvuMDpKs2VXwgM%3d
monolithic ceramic where size/low value is concerned (also the lack of polarity)
non-polarized electrolytic where polarity is a concern, but I need the benefits of an electrolytic
polarity specific electrolytic when I have an asymmetrical hot/cold circuit, or need a large value
any iteration of mylar/film/etc... where precise value is necessary (which is not very often)....also tantalum caps last a very very very long time
Why did my ceramic caps fail as bypass caps?
what was the specific application you were employing the bypass caps?
I would suggest always building a large amount of headroom into your selection....better to have too much than too little in this case....
I personally think the best use of a ceramic is for a small value input filter
there is a good reason for the prolific use of polarized electrolytic caps in power supplies....especially over 3 amps
just keep in mind that a 1/2 farad polarized electrolytic will punch a hole through your ceiling if you hook it up backwards....don't ask me how I know this (I will deny that i have ever done that)
The only thing I would use a monolithic ceramic for in that regulator circuit, is an input filter.....for everything else I would use electrolytic, and if the current draw was high enough, a supercap...
were the AA batteries lithium or alkaline....better yet 1.2-1.5 v or 3.2-3.7v?
also how far away from the batteries is the input? I.E. how long were the leads from the battery to the Vin on the regulator?
There was probably 5 inches of wire and 2 inches of PCB traces between the batteries and the input of the vReg.
