Digikey want to charge me $35 delivery - Can someone help me out?
pacman
I want to order 2 of these http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=97551910&uq=634355915004333915 to see if I have managed to track down the correct part and if it will work in the application.
Once I have got the correct item - then I'll probably be needing 20/30 at a time.
The problem is {as best i can figure} that postage for 2 is something like $35. For 2.
Suffice to say I'm not real keen on paying that sort of postage (for 2).
If someone who had a digikey account would mind adding 2 to their next order and would be prepared to post them to me in Australia then can you please contact me - I happy to pay costs, but $35 is a bit rich...
Edit: Sorry - didn't know that digikeys links were "timed" - the part I'm after is "CP-2280-ND". Hope that helps...
I would buy from either RS or Farnel if i could find this part on either of thier sites. but both seem to do 8 pin mini din, but not in the "pattern" I need
PS: I too thought 8 pin mini-din was only one pin configuration. I have at least three variaitions of "hole" configuration that I have found.
My original searches on Both Element14 and RS turned up nothing with the 'offset middle pin" {see http://australia.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=1831805 for what I mean, the graphic at the bottom is not offset - but the data sheet is - perhaps I was was misguided by the graphic?? )
BIG thanks for your help.
I shall order some locally.
PM me if you want me to get anything.
I have gotten my 8 pin mini-dins from here.
futurlec.com is very cheap, and i have ordered from them several times over the years. While i have not had any major issues, there was one. While this soured me a little, i will still recommend them with a grain of salt.
They also claim to have an office in Australasia (which i did not even know was a real word until tonight) Link They also claim to have an office in New York. All the packages they have sent me have come from Thailand or Indonesia. So that would be at least on the right side of the globe.
@mlr266 - I searched digikey AU and they didn't have the sockets. Godd to see that offer "different products" for different parts of the world, must be something to do with ...ummm... import restrictions...yeah that must be it....
