BOE Power & Reset
I am using a BS2 BOE to run an electric brewery, and would like to put the BOE in the enclosure with all the other electronics. The enclosure has both 240V and 120V circuits, and I am going to use a purchased 9V power supply to run the Stamp. If I have the power supply connected to the main switched 120V power, and leave the switch on the BOE on all the time, will it cause problems using the 120V supply to switch the BOE on and off?
Also, is there a way to have a remote reset? I have a normally open push button on the panel, and I would like this to reset the stamp.
Thanks in advance.
Thanks in advance.
