Multiplexing a DS1620 (temp) with a TSL230 (light)
Phil Pilgrim (PhiPi)
I wanted to be able to measure temperature and ambient light with the Spinneret, but I didn't want to use pins A28..A31 on the daughterboard connector, which left only four: A24..A27. It turns out that it's very easy to multiplex these two chips together. The /OE pin on the TSL230 tristates the frequency output when high. The /RST pin on the DS1620 tristates DQ when low. So, by connecting /OE to /RST and OUT to DQ, I'm able to multiplex the two chips. That leaves CLK, which I connected to S1, as shown here:
I tied S0 high and S2 and S3 low. That gives me the maximum clock rate output, with a selection between 1X and 100X gains -- and a pin left over, which I could have used to control S0.
Here's a scope trace of a reading from the DS1620 amidst the frequency output from the TSL230:
Here's the Spin program that reads both:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
nOE = 24
nRST = 24
OUT = 25
DQ = 25
S1 = 26
CLK = 26
OBJ
sio : "FullDuplexSerial"
PUB Start
sio.start(31, 30, 0, 9600)
ctra := %01010 << 26 | OUT
frqa := 1
dira[nOE]~~
dira[S1]~~
'configDS1620 'Only needed once, since it writes to EEPROM.
startDS1620
repeat
sio.str(string("Light: "))
sio.dec(light_sensor)
sio.str(string(13,"Temp: "))
sio.dec(temp_sensor)
sio.str(string(13, 13))
PUB light_sensor | time
outa[nOE]~
outa[S1]~~
waitcnt(time := cnt + clkfreq / 1000)
result -= phsa
waitcnt(time += clkfreq / 10)
result += phsa
PUB temp_sensor
outa[CLK]~~
outa[nRST]~~
wrDS1620($aa, 8)
result := rdDS1620(9) * 9 / 10 + 32
outa[nRST]~
PUB startDS1620
outa[CLK]~~
outa[nRST]~~
wrDS1620($ee, 8)
outa[nRST]~
PUB configDS1620
outa[CLK]~~
outa[nRST]~~
wrDS1620($0c, 8)
wrDS1620($02, 8)
outa[nRST]~
PUB wrDS1620(value, bits)
dira[DQ]~~
repeat bits
outa[DQ] := value & 1
value >>= 1
outa[CLK]~
outa[CLK]~~
dira[DQ]~
PUB rdDS1620(bits)
repeat bits
outa[clk]~
result := (ina[DQ] << bits + result) >> 1
outa[clk]~~
Mix-N-Match sensors... I like it.
