BS1 still won't work
i switched out the chips in my Basic Stamp 1 to another board and they worked......checked out the voltage reg and its putting out 5 volts.....reset chip and the 4mhz resonator, can I bypass the reset chip to Vcc +5 or ground or just connect MCLR on the stamp chip to Vcc or ground?.....the resonator i can replace
Add correct directive but skip COM selection or leave at Automatic !
'Test program
DO
DEBUG "Test",CR
LOOP
1. RUN a test program with serial connector or USB disconnected from BS1?
2. RUN a test program with serial connector or USB connected to non powered BS1?
3 RUN a test program with serial connector or USB connected to powered BS1?
Cheers Vaclav
