Datalogging at higher speeds — Parallax Forums
-GRIMM--GRIMM- Posts: 56
edited 2011-05-09 09:14 in Propeller 1
I am working on a project where i need to log speeds at fast rates (30 readings per second +) for 50 minutes. (about 220,000 readings)
The values for time and a sensor need to be recorded, so I need a device that can handle 60+ writes per second.
Currently with a parallax USB datalogger we are getting about 20-30 writes per second.
Are there any other sensors out there that can meet the speed requirements?
I read about Ramtron F-Ram but i can not find a source with a pre-mounted circuit board.
Ideally this would be the best bet, but my Surface mount soldering skills arent too great.
Any help is appreciated.
-Steven
    edited 2011-03-10 09:12
    You can easily get rates like those you've implied by using an SD card. Look at Kye's SD driver in the Object Exchange. He has a thread with some actual data rates posted by a variety of people with different SD cards. Both Parallax and SparkFun have microSD card boards and SparkFun has an SD card board as well.
    You can also attach a single Winbond flash memory chip (8-pin ... comes in PDIP too) to 4 I/O pins and use the I/O driver in the Object Exchange. These come in capacities up to 2MBytes. I think a microSD card would be better if you have the physical room.
  • turbosupraturbosupra Posts: 1,088
    edited 2011-03-10 09:24
    Are you able to have a pc around when doing this? Hanno's Ezlog can write to an excel spreadsheet for reasonably easy data managment
    http://hannoware.com/ezlog/
  • lonesocklonesock Posts: 917
    edited 2011-03-10 09:40
    I second the uSD card. If you don't need directory support, and need faster speed than Kye's drivers, check into FSRW (version 2.6, also in the obex).
    Jonathan
  • RS_JimRS_Jim Posts: 1,775
    edited 2011-03-11 05:00
    Grimm,
    Since you already have the hardware, why not accumulate 30 readings in a 32 byte,word or long circular buffer and write to the datalogger 1 per second?
    RS_Jim
  • -GRIMM--GRIMM- Posts: 56
    edited 2011-03-11 12:12
    The circuit is a standalone project for the 50 minutes it is recording, after which we will remove the data from it and transfer it to a computer.
    I think we will order the micro-SD card adapter and experiment.
    RS_Jim, I am not too familiar with the propeller chip yet, how would I go about doing that?
    The values being recorded come from a gyroscope (values from 0-1100 roughly) and clock time, cnt.
    -Steven
    edited 2011-03-11 12:29
    What RS_Jim suggests has nothing to do with the Propeller specifically. It's a general purpose programming technique. You have an array of some length and you stuff a value into it (one long, two longs, whatever) at the index specified by some variable like X. You then increment X by the number of items (long, word, byte, etc.) used for an entry. You wraparound the value of X to the size of the array. If the array is 10 elements long, you'd increment X like "X := (X + 1) // size" where size is 10. This creates a circular buffer for the values. To read the values out of the buffer, you'd have another index, say it's Y. You'd treat Y the same way and increment it with wraparound the same way. You'd also initialize both X and Y to the same starting value (like zero). If X == Y, then the buffer is empty. If it's not empty, you can remove a value from it and increment Y. If (X+1)//size == Y, then the buffer is full (think about it) and you have a problem. If it's not full, you can put a new value into it and increment X.
    The portion of the program that fills the buffer can run in one cog while the portion of the program that empties the buffer can run in another cog. Look at FullDuplexSerial for an example of this technique with one side written in Spin and the other side in assembly.
    edited 2011-03-12 06:05
    Thanks for that explanation Mike, I hadn't been able to get back to a computer to reply to his question about circular buffers. Full duplex serial is a great example of spin/pasm access to a circular buffer. Grimm I had additional thoughts based on the additional info supplied in your last post. Your gyro info is one word in length and time data for one second is only 30. I would use a circular buffer of longs, writing the gyro data into a long and just adding %1_0000_0000_0000_0000 to the long each tick. Then you just do wrlong data,buffpntrtail, increment the buffpntr tail, test for rollover and write it back to the hub as a long. After 30 ticks clear the long and start over. Update the hrs,mins,secs once per sec when you pick up the longs of the buffer and transfer it to storage. Each second would represent 30 longs + an hrs,mins,secs time stamp. Let the reading software parse the longs for the hrs,mins,secs,ticks info. I hope this all makes sense. I am going to use a similar technique to pass info from a cog that is reading an adc at the rate of once per millisecond, and I want to be sure that the receiving cog gets all of the readings in correct sequence.
    RS_Jim
    edited 2011-03-14 00:27
    I understand the method in theory. In SPIN, however, I would not know where to start!
  • PerryPerry Posts: 253
    edited 2011-03-14 05:13
    -GRIMM- wrote: »
    My stupid video capture uses double buffering to record 30 frames per second of video/audio to an SD card http://forums.parallax.com/showthread.php?98516-stupid-video-capture&highlight=stupid+video
    You might get some ideas from that.
    Perry
    edited 2011-03-14 17:50
    I downloaded Kye's FAT32 driver for SD cards.
    Im playing with it now trying to get it to the point where I can wire it up and test it when the sd card adapter comes in (Wednesday)
    edited 2011-03-15 10:16
    What i get from the driver produced by Kye is; to write I use:
    fat.writeLong(value)
    So if Im not mistaken, it should be as simple as taking my current USB datalogger program, and replace:
    logger.writeToFile(@buffer2,strsize(@buffer2),0)
    with
    fat.writeLong(@buffer2)
    Sound correct?
    edited 2011-03-15 11:28
    -GRIMM- wrote: »
    with
    Sound correct?
    No!
    You need to initialize theSD device
    open a file for write
    then you can write to the file
    when finished writing
    you need to close the file
    and probobably then close the device
    You should really look at how my Stupid Video works
    even Kye admits that fsrw is faster
    also writing short blocks is slower than writing long blocks (less over head)
    with "double" buffering you can receive new data while the last block is being written by the SD i/o card.
    edited 2011-03-15 19:30
    Initialize with
    programMount(stringPointer)
    programMakeDirectory(stringPointer)
    programMakeFile(stringPointer)
    Loop with data
    fat.openFile(fat.newFile(string("testfile")), "W")
    fat.writeData(@sectorBuffer, 512)
    fat.closeFile
    (possibly not opening/closing file every time)
    Finish with
    fat.unmountPartition
    Forgot there was a little more to it than that.
    I didnt realize the attachment in your video thread, I'm reading through your codes right now to try and understand it.
    -Steven
    edited 2011-03-15 19:49
    OK now you have it.
    actually I think 30 readings per second is quite slow. My only concern was that the writing might run into problems because the timing of the write to the SD card would be variable and make your data not be written at exactly equal time periods.
    edited 2011-03-16 16:32
    dt isnt as crucial as frequency.
    I just got some of the parts, I will begin experimenting and let you know how it goes. First obstacle is learning how to use a 10-bit adc instead of 8-bit.
    -Steven
    edited 2011-03-17 16:26
    Im hoping to save from creating a new thread to tackle this problem. Im using an ADC driver I found on this forum to read the value to save to the uSD card. I have a few questions on this.
    Im sorry I dont recall where I got this from, but the files are: ADC_INPUT_DRIVER.spin and ADC_INPUT_example.spin
    I took this code and modified it to work with our 1 channel 10 bit ADC. For some reason it is not behaving as I would expect.
    When using the command:
    DEBUG.dec(chanmax[1]) - The channel minimum value (of the entier run)
    DEBUG.dec(ADC.getval(1)) - I get 0
    DEBUG.dec(Chanval[1]) - I get the channel maximum (from the entire run)
    DEBUG.dec(chanmin[1]) - I get 2
    I can solve this by using 'ADC.resetmaxminall' after either Chanval or chanmax to get the current value, but I would think there is a command available to not have to reset every loop.
    Also, The value being output is 479, which coordinates to 1.479 (measured) volts. Is there a way to have it output all 4 digits (1479)?
    Thanks!
    I will begin experimenting with the uSD card soon
    edited 2011-03-17 20:14
    So far i cant get the uSD to work either. I have double checked the wiring (redid it twice just to make sure)
    I am using Kye's '#SD3.01FATDemo' to get things working. I changed the pins at the beginning of the program to validate everything. I did set this:
    _SD_WP = -1 ' -1 ifnot installed.
    because I'm not sure what it is, and I dont see a pin with this label.
    When I connect with PST i type in help and get the screen, but when I try anything card related (mount, format, etc) It just gives me: Disk IO Error
    Not sure what steps to take from here, any hints?
    In case it may be a concern, my pins are:
    _SD_DO = 21
    _SD_CLK = 20
    _SD_DI = 19
    _SD_CS = 18
    _SD_CD = 16
    3.3V, GND verified.
    -Steven
    edited 2011-03-17 20:27
    _SD_WP is write protect. uSD card don't have a write protect tab so you would want to use "-1".
    I have set _SD_CD to -1 too otherwise Kye's driver wont work for me.
    I've also had to reformat many of my SD cards before they would work with Kye's newest driver. "Fast Format" wont do it neither will the format command within Kye's driver.
    What ADC chip are you using?
    Duane
    edited 2011-03-17 21:36
    Kye's code need a real time clock chip DS1307, do you have one of those? so you need to use 6 pins.
    Somewhere I can't find it now he suggested you could comment that out.
      _clockDataPin = 29
      _clockClockPin = 28
      _cardDataOutPin = 11
      _cardClockPin = 10
      _cardDataInPin = 9
      _cardChipSelectPin = 8
    I don't care about date stamps so I use the "fsrw" code.
    I dont' see enough info about your ADC chip to comment on it.
    edited 2011-03-17 22:10
    Sorry the ADC is an 8 pin MCP3001.
    I do not have an external clock. I dont need real time but i do, however, need relative time (time between readings)
    I have a 6.25 MHz crystal.
    I tried formatting it in all the FAT formats, not quick format. Still isnt working. I will try out fsrw tomorrow.
    I was having a hard time following fsrw which is why I didnt use it at first. Trying to read through the 'Smart Video' capture files.
    -Steven
    edited 2011-03-17 23:03
    Steven,
    If you don't have an external clock you'll want to set _clockDataPin and _clockClockPin to -1.
    Duane
    edited 2011-03-18 07:39
    You will find http://forums.parallax.com/showthread.php?87289-SPI-SHIFTIN-High-Speed&highlight=MCP3001 will answer your questions about MCP3001.
    The Video capture can be used without the video part for just audio recording or data recording.
    You may need to change the clock settings if you do not use the standard 80MHz clock
    edited 2011-03-19 14:18
    Thanks for all your help.
    So far i have gotten the MCP3001 working with the program linked by Perry. I'm not sure how often it is reading, but it is only putting values out in bursts to PST. Also, it is only showing the '479' from 1.479 volts instead of 1479.
    also, I have the uSD card working with Kye's driver and demo, but not standalone.
    Im trying to get them working together, but have a few issues. Im trying two combinations. (MCP3001 code with fsrw and the same ADC code i had with Kye's driver.
    This is the first one I tried:
    'after setting all the pins
      fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, -1, -1, -1, -1, -1)
      ADC.start_pointed(Vo_p, Vn_p, Vclk_p, Vcs_p, 1, 1, 10, 1, @chanstate, @chanval, @chanmax, @chanmin)
      fat.newDirectory(string("Steriotort"))
      fat.changeDirectory(string("Steriotort"))
      fat.newFile(string("DataFile.txt"))
      fat.openFile(string("DataFile.txt"), string("W"))
      fat.writeString(string("Data"))
      fat.closeFile
      fat.openFile(string("DataFile.txt"),string("A"))
    repeat 1000
            dec(Chanval[1],@buffer2)
            ADC.resetmaxminall
      fat.closeFile
    This is where I made it to using fsrw.
    fat.mount_explicit(_SD_DO, _SD_CLK, _SD_DI, _SD_CS)
    sd.popen(string("Data.txt"),"w")
    repeat 1000
           sd.pwrite(@buffer2,12)
           ADC.resetmaxminall
    sd.pflush
    sd.pclose
    sd.unmount
    I am basically following the "Record Video" section from 'Amazing Video' and the fatengine demo from Kye to try and follow the way they create/write files.
    Neither are creating the file though. Does anyone see any large errors with either of these methods?
    Ill keep trying it out.
    -Steven
    edited 2011-03-19 20:01
    Try something like this
    'Start of ADC process
    'SDA    = Data Pin
    'SCL    = Clock Pin
    'CS     = Chip select
    'Input  = State of the pins
    'Bitcnt = Variable used to count the input bits (in this case 10)
    'Mask   = used to filter the bits into the output variable (adcvalue)
    'ADCVal = the value to write to main memory
    '' 1= output
    '' 0= input
    con
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      SD_DO         = 0     ' mount_explicit(DO, CLK, DI, CS)
      SD_CLK        = 1
      SD_DI         = 2
      SD_CS         = 3
    obj
      text  : "tv_text"
      sd    : "fsrw"
    var
      long ADCval
      byte output_str[32]
    PUB Start | writ,v
      text.start(12)
      waitcnt (80_000_000 + cnt)
      cognew (@shiftin, @ADCval)
      sd.mount_explicit(SD_DO, SD_CLK, SD_DI, SD_CS)
      sd.popen(string("DataFile.txt"),"w")
      repeat v from 0 to 99
        writ := dec_to_string(v)
        text.str(@output_str)
        write_to_SD(@output_str,writ)
        write_to_SD(string(","),1)
        text.out(",")
        writ := dec_to_string(ADCval)
        text.out(13)
        write_to_SD(string(13),1)
        sd.pflush
      sd.pflush
      sd.pclose
      sd.unmount
      text.str(string("all finished "))
    PUB write_to_SD(some_string,len) | di
        di:=sd.pwrite(some_string,len)
        if di<0
          text.str(string("SD write error "))
    '      quit
        sd.pflush
    PUB dec_to_string(value) | i,c
    '' Print a decimal number
      c := 0
      if value < 0
        -value
        output_str[c++] := "-"
      i := 1_000_000_000
      repeat 10
        if value => i
          output_str[c++] := value / i + "0"
          value //= i
          result~~
        elseif result or i == 1
          output_str[c++] := "0"
        i /= 10
        output_str[c] := 0
      return c
    DAT
    shiftin
                    org 0
    ''Set the direction and state of the I/O pins and non-recurring events
                    or              dira,   OS            ''Set OS to output
                    or              dira,   SCL           ''Set SCL to output
                    or              dira,   CS            ''Set CS  to output
                    xor             outa,   SCL           ''Set SCL pin high (1)
                    xor             outa,   CS            ''Set CS  pin high (1)
                    mov             wcnt,   #0            ''Zero wcnt
                    add             wcnt,   cnt           ''Add system counter to wcnt
                    add             wcnt,   #13           ''Add 13 clock delay to wcnt
                    waitcnt         wcnt,   Tsucs         ''Pause COG TSucs clocks
                    'rdlong          ADCtemp,PAR
    ''Start of conversion
    :loop1                                                ''Loop1  Main loop
                    xor             outa,   OS            '' Toggle OS pin
                    xor             outa,   CS            '' Toggle CS  pin low (10)
                    xor             outa,   SCL           '' Toggle SCL pin low (10), 0th falling edge
                    mov             ADCtemp,#0
                    mov             wcnt,   #0            '' Zero wcnt
                    add             wcnt,   cnt           '' Add system counter to wcnt
                    add             wcnt,   #13           '' Add 13 clock delay to wcnt
                    waitcnt         wcnt,   Tsucs         '' Pause COG until wcnt is reached by cnt
                    xor             outa,   SCL           '' Toggle SCL pin high (01)
                                                          ''   1st clock, 1st rising edge, start sample period
                    waitcnt         wcnt,   Thi           '' Pause COG Thi clocks
                    xor             outa,   SCL           '' Toggle SCL pin low  (10), 1st falling edge
                    waitcnt         wcnt,   Tlo           '' Pause COG Tlo clocks
                    xor             outa,   SCL           '' Toggle SCL pin high (01), 2nd clock, 2nd rising edge
                    xor             outa,   SCL           '' Toggle SCL pin low  (10), 2nd falling edge
                    xor             outa,   SCL           '' Toggle SCL pin high (01), 3rd clock, 3rd rising edge
                    xor             outa,   SCL           '' Toggle SCL pin low  (10), 3rd falling edge
                    xor             outa,   SCL           '' Toggle SCL pin high (01), 4th clock, 4th rising edge
                    mov             Masktmp,#0            '' Zero Masktmp
                    xor             Masktmp,Mask          '' Set initial mask = .. 0010_0000_0000
                    mov             bitcnt, #10           '' Set bitcnt = 10 (10bit ADC)
    :loop2                                                '' Loop2  This is the start of the reading of the bits
                    waitcnt         wcnt,   Thi           ''  Pause COG wcnt clocks
                    mov             input,  #0            ''  Zero input
                    or              input,  INA           ''  Place the state of all the pins into input
                    and             input,  SDA           ''  Place the state of SDA into input (if state=1 AND SDA=1  1)
                    test            SDA,    input   WZ    ''  If input AND SDA = 0  WZ=1 else = 1  WZ=0
            if_nz   or              ADCtemp,Masktmp       ''  If Z flag is false (0), then "or" ADCtemp with Masktmp
                    shr             Masktmp,#1            ''  Shift mask right 1 bit
                    xor             outa,   SCL           ''  Toggle SCL pin low (10), nth clock, nth falling edge
                    waitcnt         wcnt,   Tlo           ''  Pause COG wcnt clocks
                    djnz            bitcnt, #:loop2       ''  Decrement count by 1, jump to #loop
                    wrlong          ADCtemp,PAR           ''  Write ADCtemp to ADCval in main memory
                    xor             outa,   CS            ''  Toggle CS pin high  (01)
                    waitcnt         wcnt,   Tcsh
            jmp #:loop1                                   ''Jump to Loop1, repeat ADC endlessly
    SDA     long  |<0               ''SDA = 0000_0000_0000_0000_0000_0000_0000_0001
    SCL     long  |<1               ''SCL = 0000_0000_0000_0000_0000_0000_0000_0010
    CS      long  |<2               ''CS  = 0000_0000_0000_0000_0000_0000_0000_0100
    OS      long  |<3
    Mask    long  |<9               ''Mask= 0000_0000_0000_0000_0000_0010_0000_0000 = bitcount being measured - 1 (10bitADC-1=9)
    Tsucs   long  30                ''Tsucs = 100ns min = 8  clocks @80Mhz
    Thi     long  40                ''Thi   = 160ns min = 13 clocks @80Mhz
    Tlo     long  40                ''Tlo   = 160ns min = 13 clocks @80Mhz
    Tcsh    long  50               ''Tsch  = 350ns min = 28 clocks @80Mhz
    Masktmp       res 1             ''Masktmp = volatile value for Mask
    Bitcnt        res 1             ''Bitcnt  = volatile value for a bit counter
    wcnt          res 1             ''wcnt    = waitcnt variable
    input         res 1             ''input   = variable to store I/O pin states
    ADCtemp       res 1             ''ADCtemp = variable to store converted ADC value, gets written to Main Memory
    edited 2011-03-21 17:50
    That helps alot, thanks.
    I've been playing with that code for a few days. I understand it is an adaptation onto the MCP3001 file. That file itself works (it outputs in bursts, is that how it measures as well?)
    The file you posted works (modified it to write cnt along with the values). When i run it as it all the values are 1007, and when I change the pins to line up with the gyro, it writes cnt correectly, but then random numbers all over the board for the adc value. They vary completely, from a single digit 0, two digits, three digits, four digits.
    Im not quite sure why?
    -Steven
  • KyeKye Posts: 2,200
    edited 2011-03-21 18:20
    Yeah, sorry about my demo. It's more like a feature test program of everything. Try this out, http://forums.parallax.com/attachment.php?attachmentid=79484&d=1300756068.
    It's a bit more commented.
    edited 2011-03-21 18:22
    Examples:
    Code:
    PUB Start | writ,v
      text.start(12)
      repeat 1000
        writ := dec_to_string(cnt)
        write_to_SD(string(13,10),2)
        sd.pflush
      sd.pflush
      sd.pclose
      sd.unmount
    Saved Results (Excerpt):
    -1306321753,3
    -1303027433,0
    -1299322665,81
    -1296054649,0
    -1292374857,0
    -1289120377,0
    -1285447481,748
    -1281800521,0
    -1278340889,419
    -1274847081,118
    -1271392345,612
    -1267873849,620
    -1264399625,484
    -1260889305,0
    -1257419881,0
    -1253893465,0
    -1250438297,0
    -1246961113,80
    Code 2:
    I added the ADC input program "ADC : "ADC_INPUT_DRIVER"" found on here to attempt to write it.
    Verified it works as a standalone, but when used to write to the SD the results were:
    -1329216274,999
    -1325896850,996
    -1322119666,998
    -1318815090,1007
    -1315067682,1007
    -1311794642,1001
    -1308081666,1007
    -1304184754,1000
    -1300900018,996
    -1297360370,1001
    -1293856066,1007
    (Test output is 487)
    Ill keep trying.
    Thanks for the help
    edited 2011-03-21 19:49
    This problem intrigues me as an example of real data logging with an SD.
    but there are several things that seem to be overlooked in questions of timing
    writing small strings to the SD card is very inefficient, you need to write blocks at the size of the underlying hardware/software
    binary to decimal conversion , it would be faster to dump the raw bytes to the SD. what tools are you going to use for data analysis?
    the propeller clocks rolls over in a few seconds , using the "cnt" is not very informative , you probably need an external reference clock
    SD cards have variable write times depending on when they need to erase a new block, size of SD card is a great factor in this. Also there are so called high speed products. I am using a generic 1Gb micro SD in an adapter.
    I have made another program to address some of these problems.
    I don't have an MCP3001 so I am using sigma/delta to do the a/d conversion, my experience with these has been very good, you should expect that the conversion will provide values at their rated conversion time and only need to read them when you want the most recent value.
    I running the new version for full 60 minutes, there are few pauses so far....
    OK all done, but the buzzing has made me tired will review the results to-morrow.
    edited 2011-03-22 06:19
    Grimm,
    Jonnymac has posted a program to obex called Etimer that will give you 1 millisecond resolution. You could tie that together with your data from your adc and write the data to the card once per second using a circular buffer to store the data in hub ram until you write it to the card.
    RS_Jim
    edited 2011-03-22 08:59
    Thanks for the replies.
    Perry, thanks. I will run that program when I get back to my computer.
    RS_Jim. I will use that program to record time instead of cnt. I did not know one was available!
