Using the USB port on a Proto Board USB ?
This is probably a newbie question (I'm a newbie !)...
Is it possible to use the USB port in a Proto Board to talk with a USB flash drive ?
The best Propeller storage options are the EEPROM, an SD card, or serial data exchange to a connected PC.
What are you trying to accomplish?
OBC
OBC
This might be of intrest for you to read its a little advanced but might get you started in the right direction.
http://obex.parallax.com/objects/652/
Also I second Mike Green the SD is a little easier.
Dan
I like SD much better for datalogging. I think SD is faster as well. I've had very few SD cards not work with the SD drivers available for the Propeller.
You'll find robust code, working even with no pull ups. So you can buy (or make) a compliant adapter. There re many available, cheap and good. But you can also use a stripboard or a perf board little bit of time to create your reader.
On the net you can also find instructions to use a micro sd, soldering the micro SD to SD adapter pads.
Massimo
