+/- 10 input ADC
Hello
I have a need to read a -10vdc to +10vdc two wire signal and was looking to see if anyone knows of a ADC that can read it?
The way you do that will depend on your exact circuit. This will almost definitely add a little noise, but no big deal.
I also use Max1032 and Max1302 for more precision but these are harder to get and prototype with.
Parallax really should advertise the fact the MAX1270 ADC can do bipolar inputs on that product page. Its a big selling point.
Do you happen to have any sample code to setup the MAX1270 with the Prop for +/- input?
Thanks again
You can also do this directly in the Prop without any external chips; only two resistors and a small cap. I believe there is an appnote about Sigma Delta A/D.
The conversion results will be skewed due to a non-zero reference point, but that is easily dealt with by a simple subtraction. Personally I have not done this with the Prop, but many time with an SX processor with excellent results. I believe the Prop should also deliver good results, and the code to implement this will be less than the work required to interface to an external chip.
Cheers,
Peter (pjv)
http://obex.parallax.com/objects/513/
