Memsic 2125 in Matlab with Arduino board — Parallax Forums
jomillejomille Posts: 2
edited 2011-03-10 17:47 in Accessories
I have a Memsic 2125 chip hooked up to a Arduino board that is reporting raw acceleration data back to Matlab. Using the code here (http://arduino.cc/en/Tutorial/Memsic2125?from=Tutorial.AccelerometerMemsic2125) I read the accelerationX and accelerationY in Matlab via the serial port. Now I need to convert this into an actual degree angle for X and Y. Using the data I am getting from the board in acceleration, how can I convert this into an angle?
    edited 2011-03-08 20:46
    http://arduino.cc/en/Tutorial/Memsic2125 recommend you go here and the Arduino forums.
  • jomillejomille Posts: 2
    edited 2011-03-09 04:32
    Yep, got that..As you see from my post, I am already familiar with that tutorial and that code. My question lies with getting tilt angle from the raw acceleration data. This seems like a question that would be more suited for this forum.
    edited 2011-03-09 07:53
    You are using Matlab and an arduino. All code will be for those devices. Why do you think basic stamp/propeller code will work with your setup?
    edited 2011-03-09 10:44
    Well, maybe someone who has PBASIC or SPIN experience/s could share and the OP could extrapolate.
  • WhitWhit Posts: 4,194
    edited 2011-03-10 07:35
    @jomille - did you see the Nuts and Volt article "Its All About Angles" that is linked on the Memsic 2125 page on the Parallax site? As PJ suggested, you might be able to do a bit of extrapolating from that.
    Article - http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol3/col/nv92.pdf
    Code - http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol3/code/nv92.zip
  • Mike GMike G Posts: 2,702
    I'm not sure how you would go about converting a change in velocity to an angle.
    But converting a linear range to an angle is fairly straightforward. If you have a 1000 unit range through 180 degrees then 180/1000 = 0.18 units per degree. Or [step = pi/units]; therefore
    f(x) = (sin(x*step) + 1) * offset
    If it's not linear than you need to a conversion factor.
    Edit: read the article in whit's post. It has the conversion information.
