How Many EmbeddedBasics? — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2011-03-09 09:12 in Propeller 1
How many run in a single Propeller chip?
  • BeanBean Posts: 8,129
    edited 2011-03-08 11:39
    Embedded Basic can be compiled for three different platforms.
    1) Telnet interface for the spinneret
    2) PST interface to PC
    3) Stand-alone PS/2 keyboard and TV output
    All three are the same except for the INPUT and OUTPUT methods. All run on a single propeller chip.
    What is missing and a way to get programs in-to and out-of the development environment. Possible a PST type program that can record and playback would work for the PST version.
    Bean
    edited 2011-03-08 12:20
    How much program space is available with the TV/PS2 version? What did you decide to do about putting the program in EEPROM?
    edited 2011-03-08 15:00
    What I really mean to say is how many instances of EmbeddedBasic can load and run into a single Propeller chip all at the same time? For example, if it takes up 2 cogs, then four instances could run at the same time.
    edited 2011-03-08 15:09
    @David, There is 4K for the BASIC program (vars are stored in a seperate area). Using the EEPROM would be really slow with GOTO having to search for the line number, it would mean a different program structure would be needed (like labels instead of line #s).
    Humanoido, It is only setup to run as 1 instance, but could probably be modified to run multiple. If we (the propeller community) want to create a serious embedded BASIC, then it should be well thought-out and documented (my embedded basic was just a "can it be done" project and is NOT well thought-out or documented).
    Bean
  • SapiehaSapieha Posts: 2,964
    edited 2011-03-08 15:19
    Hi Bean.
    In one of posts before I referenced to MY post in another thread that I wrote ON Line number search to improve speed on read directly from SPI/I2C devices. BUT Now I think You not readed it at all.
    Bad but it is You that decide what You will use.
    Bean wrote: »
    Bean
    Bean wrote: »
    Why not just build a line number to source program offset translation table to speed up GOTO and GOSUB? When the user types RUN you could first scan the entire program for GOTO and GOSUB statements and remember the target line numbers. Then make a second pass looking for those numbers and remembering their source code offsets. After that, GOTO and GOSUB could just use that table to find their target lines with no searching.
