Timer Obj crashes my program
Trying to figure out why the TImer Obj would cause wierd issues in my program. My program uses getStr to receive a message from my GPS every 100ms, then continues to execute the Main loop below. The PUB LapTimer below captures IR and manipulates the TIMER. I have narrowed it down to:
When I call getStr from FullDuplexSerial and any ref to the Timer Obj. I can use either successfully, but when I try to have them both working at the same time my program goes whacky.
Example, I can comment out the getStr line (first line of main loop) OR I can comment out the references to TIM in the LapTimer function. But if both are included the program dies.
Any help is appreciated!
CON
_clkmode = xtal1 + pll16x
'_xinfreq = 5_000_000
_clkfreq = 80_000_000
cmd_length = 256
GPS_BAUD = 57600
GPS_RX = 1
GPS_TX = 0
clockDataPin = 29
clockClockPin = 28
cardDataOutPin = 12
cardClockPin = 13
cardDataInPin = 14
cardChipSelectPin = 15
BRAKE_POT = 26
THROTTLE_POT = 27
angleCS = 16
angleDIO = 17
angleCLK = 18
_irpin = 24
_ics = 6300
_icd = 1300
VAR
'-----Program Direction
long funct 'what are we doing?
'-----GPS Variables
long x 'Counter
long y 'GPS Bytes
byte z[10]
'-----New Session Number
long fileNum 'Current log file
'-----Bike Control Measurements
long potPos1 'POT Position
long potPos2
long potPin 'Current POT
long pot1low
long pot1high
long pot2low
long pot2high
'-----Lean Angle Sensor
long Pitch
long Roll
'-----Blinky Status LED
Byte statLED
'-----User Shutdown
Byte shutDown 'Detect user off
'-----Lap Timer
long ibuff 'index buff
long buff[60] 'store sample times
long stack[60] 'for sample running in cog
long lap 'check timing
byte irmode
byte beacon
byte valid
byte first
long clock
OBJ
PST : "Parallax Serial Terminal"
GPS : "FullDuplexSerialPlus"
POT : "BlakePOT3"
FAT : "SD2.0_FATEngine.spin"
NUM : "Numbers"
TIM : "Timer"
PUB Main
if PST.Start(115200)
pst.str(string("PST Started!"))
pst.char($0D)
if GPS.start(GPS_RX, GPS_TX, 0, GPS_BAUD) 'startup GPS serial
pst.str(string("GPS Started!"))
pst.char($0D)
else
pst.str(string("GPS Failed!"))
pst.char($0D)
if FAT.FATEngineStart(cardDataOutPin, cardClockPin, cardDataInPin, cardChipSelectPin, clockDataPin, clockClockPin)
pst.str(string("FAT Started!"))
pst.char($0D)
else
pst.str(string("FAT Failed!"))
pst.char($0D)
NUM.init
pst.str(string("NUM Started!"))
pst.char($0D)
cognew(LapTimer,@stack[1000])
pst.str(string("LAP Started!"))
pst.char($0D)
if TIM.start
pst.str(string("TIM Started!"))
pst.char($0D)
else
pst.str(string("TIM Failed!"))
pst.char($0D)
pst.char($0D)
funct := 5
statLED := 0
shutDown := 0
repeat
if funct == 5
pst.str(string("Begin Data Logging!"))
pst.char($0D)
pst.char($0D)
waitcnt(clkfreq + cnt)
repeat while shutDown <> 1
statLED++
GPS.getstr(Str12)
PST.str(Str12)
FAT.writestring(Str12)
FAT.writestring(string(","))
pst.char(",")
POT.Main(BRAKE_POT,@potPos1)
FAT.writestring(NUM.tostr(potPos1, num#dec))
pst.dec(potPos1)
pst.char(",")
FAT.writestring(NUM.tostr(pot1low, num#dec))
pst.dec(pot1low)
pst.char(",")
FAT.writestring(NUM.tostr(pot2high, num#dec))
pst.dec(pot1high)
pst.char(",")
POT.Main(THROTTLE_POT,@potPos1)
pst.dec(potPos1)
pst.char(",")
FAT.writestring(NUM.tostr(pot2low, num#dec))
pst.dec(pot2low)
pst.char(",")
pst.dec(pot2high)
pst.char(",")
if lap == 0
pst.str(clock)
if lap == 1
FAT.writestring(clock)
pst.str(clock)
lap := 0
clock := string("---")
FAT.writebyte($0D)
PST.char($0D)
if ina[23] == 1
shutDown := 1
if statLED == 5
if dira[25] == 1
dira[25] := outa[25] := 0
else
dira[25] := outa[25] := 1
statLED := 0
pst.char($0D)
pst.char($0D)
pst.char($0D)
pst.str(string("Stop Indicated!"))
pst.char($0D)
FAT.closefile
waitcnt(clkfreq / 2 + cnt)
FAT.unmountPartition
pst.str(string("Ready To Power Off!"))
funct := 99
PUB LapTimer | kbd, n, i, mark, space
waitcnt(clkfreq * 5 + cnt)
irmode := 0
first := 0
lap := 0
repeat
if irmode == 0
repeat 30
waitpeq(0,|<_irpin,0) 'wait for any ir on
buff[ibuff++] := cnt
waitpeq(|<_irpin, |<_irpin, 0) 'wait for space
irmode := 1
if irmode == 1
beacon := 1
valid := 0
i := 2
repeat i from 2 to ibuff step 2
space:=(buff[i ]-buff[i-1])/80 'space used
if beacon == 3
if space < (_icd + 100)
if space > (_icd - 100)
beacon := 1
valid++
if beacon == 2
beacon := 3
else
beacon := 1
if beacon == 1
if space < (_ics + 100)
if space > (_ics - 100)
beacon := 2
else
beacon := 1
if valid == 3
if first == 1
clock := TIM.ShowTimer 'string("lap")
TIM.reset
TIM.run
lap := 1
if first == 0
TIM.reset
TIM.run
first++
irmode := 0
ibuff~
n~
i~
quit
irmode := 0
ibuff~
n~
i~
DAT
Str12 word "1", 0
Also, your usage of Str12 is questionable. You want to refer to it as @Str12. With that out of the way what is the expected length of the string returned by the getStr method call (you only have two words reserved, i.e. 4 bytes)?
