AC speed control - Phase angle fired TRIAC?
Does anyone have any experience with controlling the phase angle triggering of a TRIAC? I am trying to do some speed control of an AC powered model train (a circa 2004 3-rail Lionel train set) using a Propeller chip. From what I gathered so far the normal power supply that comes with the train set is triggering the output of a TRIAC to essentially "chop" the output from a 20 VAC transformer to produce the speed control of the train. If you advance or retard the phase angle firing you essentially induce a slight potitive of negative offset voltage which triggers the train's bell or whistle into action.
It seems to me that the Propeller chip running at 80 MHz should run plenty fast enough to provide some very nice timing control on a pokey 60 Hz supply voltage. Has any one tried this, or any ideas on how to go about triggering the TRIAC (or DIAC?) to get phase angle controlled output?
Once you trigger it, it stays in conduction till the end of the alternation (like an SCR), but a TRIAC
can be triggered to conduct on both halves of the cycle.
There are specialised TRIACs which can be triggered in all four quadrants.
When controlling inductive loads it's imperative that you include a snubber network.
What does the snubber network do and where do I find out more about it?
TRIAC's MT1 and MT2.
Its purpose is much the same as a commutation diode in a DC
circuit when that involves an inductive load.
Your train motor is DC powered, correct?
Model trains are fun, post some pictures.
I'll go out on a limb:
A suitable snubber, in a general application, would be 100Ω in series with 0.1uF.
Over-rate those components, use a non-inductive resistor [no wire-wounds].
Ready-made snubber networks are available, common industrial devices,
they look like a big mylar cap.
As for the train motor itself, many of the old Lionel's ran on AC but the motor was built as a "universal" motor with brushes that can run very nicely on DC. The reversing was carried out with a relay onboard that alternated each time power was applied. By converting to DC, you could have a smoother running system.
Cheers,
I am a bit surprised there isn't more information avaialble on how these things really work and how to build your own power supply. I would have thought all of this had already been done long ago using a Stamp or Propeller micro. I see someone has posted some DCC train code onthe Propeller exchange - but DCC is DC powered trains, not AC powered units.
Looks like I will have to put a scope on the power unit that came with the set and have a good look at the output myself to see what is going on.
