No Stamp found, but I get data from the program and echo from the Identify routine
After gathering dust in the junkbox since 2003, I decided to relearn Stamp programming. I downloaded the latest editor (2.5.1 for XP). I can't get it to talk to the Stamp. I have:
BS2p24 on the Demo Board
RS232 COM1 via the same DB9 straight cable I use for all of my devices
Tried several power supplies. I get good 5V from the 7805 on the Demo Board and on the Vdd pin of the Stamp.
"Identify" shows COM1 and 2, for COM1 no loopback but yes for echo. I can see data go in and out of the Sin and Sout pins.
Here's the strange part: It's running a program, and I can see the data in the debug window. The last thing I used it for was the LTC1298 A/D converter. I have a 10K pot wired to the chip and the data in the debug window changes as I change the pot value.
I removed 2.5.1 of the editor and installed 1.33 from the original CD, but that didn't make any difference so I'm back on 2.5.1.
Am I missing something obvious? Is it because there's a program running that I can't send data to the Stamp? If so, how do I stop it, since it runs as soon as you power it up?
Dave
Dave
Can you please upload the program code you're using so we can all take a look at it (with multiple analytical eyes)? It sounds like something fairly straightforward.
Mark
Since I've forgotten everything about the Stamp, I was starting with the usual "hello world" code from the manual:
' {$STAMP BS2p}
DEBUG "Hello World"
When I try to run, I get the "No BASIC Stamps found" popup. It's weird that I get an echo from the ID function, and can see the data coming from the Stamp.
Now it's time to get into real trouble!
Glad you got it going.
"real trouble" can be a good thing!
Welcome to the forums.
