Clever Way To Interface Basic Stamp with 3.3v Device
Sorry, I don't have the answer, but I am asking the question. I have exactly 1 device that I would like to interface with my BS2 that is 3.3v. It is the XPort Pro Ethernet Adapter. It needs 3.3v supply at 220ma and then is serial in and out at the same level.
I would assume I can use a to-92 package regulator for the power supply. I would like to NOT use a giant IC for the other levels.
First, will the BS2 see 3.3v data? If so, I can then just use a couple of resistors to create the 3.3v to send to the device from the BS2
THANKS --
Greg
THANKS --
Greg
Going the other way, the BS2 will produce a high voltage of about 4.3V. You could put two silicon diodes in series with this to drop the voltage by 2 x 0.7V = 1.4V which would bring it into the range of acceptable voltage for a 3.3V device or you could use a voltage divider like 1K Ohms : 3.3K Ohms to provide about a 1.2mA load and 3.3V or less out.
Greg
If I use a couple of 1n4148 diodes would I also use a pull down resistor?
http://forums.parallax.com/showthread.php?85474-How-to-safely-interface-a-5v-signal-to-the-propeller
