SD Card Pins
I have DongleBasic running on my PropStick.
It uses pins[11..8].
I wanted to try to put it on other pins such as pins[25..22].
To do this I edited BB_definitions.spin like this
I can perform the "FILES" command but can't load any.
Same thing for pins[15..12].
Edit: The problem was caused by my "Antique" 32MB card.
What are there any restrictions on which pins must be used?
Are there other things that must be edited to make this work?
Why do I want to do this?
I use plugboards and have my SD Card socket mounted atop
an 8 pin 25mil square header that can be directly plugged into the
plug board from DIP pins 27 to 34. This straddles the crystal and
gets power from the DIP pins 29 and 32. It would work very nicely
with no wiring and not take up any extra plugboard space.
Duane
{{ spiDO = 25 ' zig
spiClk = 24
spiDI = 23
spiCS = 22
spiDO = 8 ' Original Pins
spiClk = 9
spiDI = 10
spiCS = 11
However, this doesn't work, well sort of.I can perform the "FILES" command but can't load any.
Duane
Everything works great now.
I replaced my antique 32MB, (2001), card with a new 512MB one. I was surprised that the FILES statement worked but nothing else on pins[25..22].
Here are some pictures to show how to put one together.
Pre-bend the tiny socket pins to match those of the header.
Add the 1uF ceramic capacitor.
Add 30 gauge wire between the 2 ground pins and the corners of the metal cover.
Bend the pins on the header over as in the photo so they are nearly in line with the adjacent pin. Note, one pin is left straight. Cut this pin shorter to be even with the bent ones. Remove the 2 middle pins.
Solder one end of the 6 20kO 603 SMT resistors to the socket pins sort of like a "tomb stone".
Add 30 gauge wire across the tops of the resistors and the 3.3V on the capacitor.
Measure the resistors to make sure they are connected properly and there are no shorts.
Solder the header to the socket pins.
This is how it is mounted on my plugboard.
BTW, that is my version of the PropStick. The EEPROM, Crystal, Regulator, and other parts are sandwiched between the top 2 I.C. sockets. The bottom I.C. socket is sacrificial, in case I break a pin off it can be replaced
Edit BB_definitions.spin like this
spiDO = 25
spiClk = 24
spiDI = 23
spiCS = 22
Duane
