Sensirion sht1 reads high
![Ray0665](https://forums.parallax.com/uploads/userpics/776/nEK2UPF6RHP1D.gif)
I have the sensirion sht1 on the Prop demo board and am using the Sensirion.spin object from the obex.
It is consistently returning a high reading of almost 3 degrees C (5F). I' have it compensated for VCC of 3.3 volts and modified it to return a fixed point value scaled by 1000 as follows
' celsius = 1000(-39.63 + (0.01t))
return 10*ReadTemperature-39630
does anyone have any suggestion?
I have to ask, what is the reference sensor and is it in direct contact with the SHT on the demo board?
The SHT11 would not have that much self heating, less than 0.1 deg. Celsius when reading twice per second.
The bottom line is I don't, but I have a Galileo thermometer in the same room and a Lacross 2300 base station in the same room and both read lower than the sensiron, and they are physically close enough to the sensor that it should be in the same range. I don't expect a match but I think 5F is a bit much.
To be clear there are two objects in the exchange, I am not using Sensirion_full so I don't have access to the heaters with this object.
The LaCross weather station is in its own micro-environment too. I don't know about its accuracy, but I wouldn't be at all surprised if it also uses the Sensirion sensor too. The SHT series is very popular.
The Galileo (buoyancy) thermometer, I don't know, how accurate can those be?
Tracy , before I forget thanks for responding...
After my reply I moved the Galileo right next to the demo board and there are no lights on in the room.
I honestly don't know about the Galileo but the tags are marked at 2F increments.
May I assume, from the lack of other suggestions that other than environment it is what it is with regards to the SHT1?
and I am seeing readings within 1 degree F of each other, well within expected tolerances.
I guess I'm now like the proverbial guy with three watches
Anyway thanks again.
