USB2SER to BS2 et al
I have been having trouble getting the Parallax USB2SER adapter to work with a Stamp. The problem is that I want to use a BS2P40, which does not fit on a Board of Education. So I have it on a breadboard. The adapter has 4 lines out (Vss, Tx, Rx, RES). It's actuallly the Propeller plug. I was informed that it can be used with the BS2 series. Does anyone have a schematic of a solution? It would be most helpful. Thank you
