Touch screen help.
Like a well buttered piece of toast that ALWAYS falls face down when you drop it, my 5" touch screen did just that and it shattered in one corner.
The screen is labeled with the following info:
"253G-18202RS" and "HB050-DM402-12A"
second line: "10070302213"
The "0" could be either zero or Ohhh.. Hard to tell but I think they are zero's.
The screen is 2.9" X 4.7", and 5.5" on the diag.
Any you guys that deal with this stuff all the time got a clue from the numbers who makes this unit??
Any help out there today?? Mike B.
Mike B.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=TSTFT5.7I%23-ND
Of course, if you could tell us what this came off of, or where you got it to begin with, it would help track down the original part.
PE - Inversely? I must be wasted. It's directly. The inverse thing goes with spandex, but nevermind.
Before you bother telling me to contact the Mfr (Rand Mcnally) I have been beating my head against the wall with them to NO avail. They don't have a repair facility. If it isnt warranty replacement I'm out of luck. So, shelve the seller of the unit...
Anyway, you gave me enough confidence to pull the unit apart and remove the display/touch screen. They are indeed two seperate units. The display itself has a ribbon cable/PCB type connection to the mother board. On top of the display is the touch screen that has FOUR wires/PCB coming straight off the bottom edge (the long dimension) and SLIGHTLY off center to the right of the touch screen. The ribbon cable from the touch screen looks to be maybe 1" long and is surface mounted to four pads on the display cable. I can handle that soldering/unsoldering no problem.
With the display/touch screen out I can get a little more accurate measurements on the touch screen itself. The diag now appears to be 5.4" extreme edge to edge. The X/Y measurements are 2.8" X 4.6".
Now the big issue is that it appears to be bonded to the display. The touch screen is ruined so not worried about removing it but I am worried about damaging the display itself. Any idea how to seperate the two items??
I sure appreciate the help on this. I have only had the unit 4 months and have come to depend on it!! lol.
Mike B.
@microcontrolled: I noticed that on the cable FROM the touch screen there is a part number: "JC05005BA". Now that might be the part number for the ribbon/PCB connector itself. The first part number in my first post was on the back of the display so that is most likey for the display and has nothing to do with the touch screen itself..
Mike B.
After a six pack to calm me down and a 14 hour operation, I was able to seperate the touch screen from the display and I hooked the display back up and it still wprks perfectly!!!
I also just noticed a part number on the touch screen. 051005. Now to find a suitable replacement
I have not yet removed the ribbon cable connection to the touch screen as it make a handy protector for the display..
item: 320643005448
Mike B.
This experience has given me an idea for my Propeller project. In thirty words or less what's involved in "talking" to a touch panel with a prop?? I have a 7" LCD monitor I am using and adding a touch panel would open up a whole new world for my user interface..
Mike B.
This experience has given me an idea for my Propeller project. In thirty words or less what's involved in "talking" to a touch panel with a prop?? I have a 7" LCD monitor I am using and adding a touch panel would open up a whole new world for my user interface..<.........I would like to see this
