Block CCTV signal flowing in reverse
I have a circuit where I'm using a couple ADG426 1x16:1 switcher units with a BS2P40 controlling them. The issue I'm seeing coming up as I plan to test this design is that when certain feeds are active they may flow to not only the input but to the outputs. Is there a way I can keep signal flowing in only one direction? I've been looking at electrolytic capacitors and diodes. Diodes make the most sense but it seems like the forward voltage drop would be too much when dealing with the low voltages involved in CCTV. The other option I see is the electrolytic capacitor. They are obviously polarized but what happens if signal flows into them from the other direction?
Another option I see would be SPST relays but running 16 relays off the few pins I have remaining seems unlikely without another IC communicating via I2C or a decoder.
Really, all I need is a way to block backwards signal. I'm certain there are other options but I'm ignorant as to what they may be.
Let me know if this helps:
If that's not a possibility, this circuit might work to block a ground-referenced DC video signal from back-feeding:
It's certainly not as good as using the MUX, though.
To me, it still sounds like you should be able to route all of your inputs through the multiplexer(s). If you have 20 inputs, are you using a 16-input multiplexer and a 4-input? I think adding additional multiplexer inputs will be much easier and cleaner than using relays or other devices. You can probably just tie the outputs of the multiplexers together for your output since they have EN pins to disconnect all inputs completely (although I didn't read the spec sheets very carefully so I may be wrong).
I have done some stuff with switched video like this (it's been a while), but I used matrix-based chips with multiple inputs and multiple outputs that could be tied together anyway I wanted to.
