Driving Stepper Motors in FemtoBasic
Here is a demo program for driving multiple stepper motors. This example moves from one position to another using "Linear Interpolation". I.e. the several motors move in synchronous motion so the motors that have less distance to travel move at a slower speed so they all arrive at the destination at the same time.
Movements can be done in either absolute or relative modes.
Note! I don't like the term "Steps" when working with stepper motors.
I prefer the term "Cycles". It has deeper meaning. A Cycle is a basic unit of motion from one step code pattern to the next same step code pattern.
Steps should refer to fractions of a cycle. In this example there are 8 steps per cycle. Some would call these as "Half Steps".
I would call a conventional "200 Step" stepper motor a "50 Cycle" motor.
Duane
NEW
10 PRINT "Demonstrate Driving Stepper Motors"
11 PRINT " Using Linear Interpolation"
12 PRINT " Duane C. Johnson 2011/03/02"
13 PRINT "This example uses 2 stepper motors."
14 PRINT "This technique can be used with any"
15 PRINT " number of stepping motors."
16 PRINT "The range of movement is +-16383 Steps"
17 PRINT " or +-2047.875 Cycles"
20 REM H,K = Relative Motor Movement
21 REM I,L = Absolute Motor Starting Position
22 REM J,M = Absolute Motor Destination Position
23 REM N,O = Incremental Step Movement
24 REM P = Number of Increments per Movement
25 REM Q = Quarry
26 REM C,E,G,F,T = Used by Formatted Display Functions
90 I = 0 : L = 0 : OUTA[7..0] = $11
100 REM Start Point
110 PRINT " | 0=Quit |"
120 PRINT " | 1=Move Absolute |"
130 PRINT " | 2=Move Relative |"
170 DISPLAY 7 : INPUT " " ; Q
180 Q = Q & $3 : Q = Q // 3
190 GOTO 190+1+Q : REM CASE
191 STOP : REM CASE 0
192 GOTO 300 : REM CASE 1
193 GOTO 400 : REM CASE 2
300 REM Input Move to Absolute Position
310 INPUT "Stepper Position In 1/8 Cycles Az, Alt ? "; J,M
320 H = J - I / $20000
330 K = M - L / $20000
390 GOTO 500
400 REM Input Move to Relative Position
410 INPUT "Stepper Movement In 1/8 Cycles Az, Alt ? "; H,K
420 GOTO 500
500 REM Find the Number of 1/8 Cycles
510 N = H : IF N < 0 THEN N = 0 - N : REM N is Temporary
520 O = K : IF O < 0 THEN O = 0 - O : REM O is Temporary
530 P = N : IF O > P THEN P = O : REM # OF 1/8th Cycles
540 N = H * $20000 / P : REM N = Az Increment
550 O = K * $20000 / P : REM O = Alt Increment
600 REM Drive the Steppers
610 FOR U = 1 TO P - 1
620 I = I + N : L = L + O : PRINT ".";
630 GOSUB 1000
640 REM GOSUB 4000
641 REM GOSUB 5000
650 NEXT U
660 I = I + N : L = L + O : PRINT ""
670 REM GOSUB 4000
671 REM GOSUB 5000
700 REM Fix Final Position due to Divisional Rounding
710 IF (I > 0) AND (N > 0) AND ((I & $00010000) > 0) THEN I = (I + $00010000) & $FFFE0000
715 IF (I > 0) AND (N < 0) AND ((I & $00010000) > 0) THEN I = I & $FFFE0000
720 IF (I < 0) AND (N > 0) AND ((I & $00010000) > 0) THEN I = (I + $00010000) & $FFFE0000
725 IF (I < 0) AND (N < 0) AND ((I & $00010000) = 0) THEN I = I & $FFFE0000
730 IF (L > 0) AND (O > 0) AND ((L & $00010000) > 0) THEN L = (L + $00010000) & $FFFE0000
735 IF (L > 0) AND (O < 0) AND ((L & $00010000) > 0) THEN L = L & $FFFE0000
740 IF (L < 0) AND (O > 0) AND ((L & $00010000) > 0) THEN L = (L + $00010000) & $FFFE0000
745 IF (L < 0) AND (O < 0) AND ((I & $00010000) = 0) THEN L = L & $FFFE0000
770 GOSUB 1000
790 GOSUB 4000
791 GOSUB 5000
810 GOTO 100
1000 REM Output Step Codes
1200 REM Stepper Connected to Pins[3..0]
1210 GOTO 1210+1+((I & $E0000) SHR 17)
1211 OUTA[3..0] = %0001 : GOTO 1219 : REM 0 0,1
1212 OUTA[3..0] = %0011 : GOTO 1219 : REM 1 2,3
1213 OUTA[3..0] = %0010 : GOTO 1219 : REM 2 4,5
1214 OUTA[3..0] = %0110 : GOTO 1219 : REM 3 6,7
1215 OUTA[3..0] = %0100 : GOTO 1219 : REM 4 8,9
1216 OUTA[3..0] = %1100 : GOTO 1219 : REM 5 A,B
1217 OUTA[3..0] = %1000 : GOTO 1219 : REM 6 C,D
1218 OUTA[3..0] = %1001 : GOTO 1219 : REM 7 E,F
1219 REM
1400 REM Stepper Connected to Pins[7..4]
1410 GOTO 1410+1+((L & $E0000) SHR 17)
1411 OUTA[7..4] = %0001 : GOTO 1419 : REM 0 0,1
1412 OUTA[7..4] = %0011 : GOTO 1419 : REM 1 2,3
1413 OUTA[7..4] = %0010 : GOTO 1419 : REM 2 4,5
1414 OUTA[7..4] = %0110 : GOTO 1419 : REM 3 6,7
1415 OUTA[7..4] = %0100 : GOTO 1419 : REM 4 8,9
1416 OUTA[7..4] = %1100 : GOTO 1419 : REM 5 A,B
1417 OUTA[7..4] = %1000 : GOTO 1419 : REM 6 C,D
1418 OUTA[7..4] = %1001 : GOTO 1419 : REM 7 E,F
1419 REM
1910 RETURN
2000 REM Print a HEX Number
2001 REM Pass C = # of Printed Characters, Value Unaffected
2002 REM Pass E = the Number to be Printed, Value Unaffected
2003 REM Pass G = Comma Flag, Value is comma placement Value Unaffected
2004 REM F = Scratch Variable
2005 REM T = Scratch Variable
2010 PRINT "$" ; : REM Possibly done in the calling routine
2020 FOR T = C // 9 TO 1 STEP -1
2030 F = ((E REV (T * 4)) REV 4) + 48
2040 IF F > 57 THEN F = F + 7
2050 DISPLAY F ;
2060 IF G <> 0 THEN IF ((T-1) // G = 0) & (T<>1) THEN PRINT "," ;
2070 NEXT T
2190 RETURN
3000 REM Print a BINARY Number
3001 REM Pass C = # of Printed Characters, Value Unaffected
3002 REM Pass E = the Number to be Printed, Value Unaffected
3003 REM Pass G = Comma Flag, Value is comma placement Value Unaffected
3004 REM F = Scratch Variable
3005 REM T = Scratch Variable
3010 PRINT "%" ; : REM Possibly done in the calling routine
3020 C = C // 33 : REM Keep in bounds
3040 F = $1 : F = F REV C : REM Using REV
3050 FOR T = C // 33 TO 1 STEP -1
3060 IF E & F = 0 THEN PRINT "0" ; : REM "0"
3070 IF E & F <> 0 THEN PRINT "1" ; : REM "1"
3080 IF G <> 0 THEN IF ((T-1) // G = 0) & (T<>1) THEN PRINT "," ;
3090 F = F SHR 1
3100 NEXT T
3910 RETURN
4000 REM Display the Stepper Accumulators in Binary
4110 PRINT "Az ";
4120 E=I:C=32:G=20:GOSUB 3000
4130 PRINT " Alt ";
4140 E=L:C=32:G=20:GOSUB 3000
4150 PRINT ""
4910 RETURN
5000 REM Display the Stepper Accumulators in Hex
5110 PRINT "Az ";
5120 E=I:C=8:G=5:GOSUB 2000
5130 PRINT " Alt ";
5140 E=L:C=8:G=5:GOSUB 2000
5150 PRINT ""
5910 RETURN
RUN
Duane
NEW
25 REM Q = Quarry
100 REM Start Point
390 GOTO 500
420 GOTO 500
630 GOSUB 1000
640 REM GOSUB 4000
641 REM GOSUB 5000
650 NEXT U
670 REM GOSUB 4000
671 REM GOSUB 5000
770 GOSUB 1000
790 GOSUB 4000
791 GOSUB 5000
810 GOTO 100
1219 REM
1419 REM
1910 RETURN
2050 DISPLAY F ;
2070 NEXT T
2190 RETURN
3090 F = F SHR 1
3100 NEXT T
3910 RETURN
4110 PRINT "Az ";
4130 PRINT " Alt ";
4150 PRINT ""
4910 RETURN
5110 PRINT "Az ";
5130 PRINT " Alt ";
5150 PRINT ""
5910 RETURN
RUN
OBC
NEW
12 PRINT " Duane C. Johnson 2011/03/03"
16 PRINT "The range of movement is +-8191 Steps"
17 PRINT " or +-1023.875 Cycles"
18 PRINT "A File Containing Move Codes Can be Used"
19 PRINT " To Perform Preprogramed Movements"
25 REM Q = Quarry
27 REM SD Card uses pins[11..8]
100 CLOSE : REM Start Point
140 PRINT " | 3=Move Using File |"
150 PRINT " | 4=Download to File |"
180 Q = Q & $7 : Q = Q // 6
191 STOP : REM CASE 0=Quit
192 GOTO 300 : REM CASE 1=Move Absolute
193 GOTO 400 : REM CASE 2=Move Relative
194 GOTO 500 : REM CASE 3=Move Using File
195 GOTO 600 : REM CASE 4=Download to File
196 GOTO 100 : REM CASE 5
380 GOSUB 6000
390 GOTO 100
420 GOSUB 6000
490 GOTO 100
500 REM Run From a Data File
505 OPEN "StpMtr.mov" , R
510 READ Q
511 PRINT Q
520 IF Q = 5 THEN GOTO 100
530 IF Q <> 1 THEN GOTO 580
540 READ J,M
541 PRINT J,M
550 H = J - I / $20000
560 K = M - L / $20000
570 GOSUB 6000
575 GOTO 510
580 READ H,K
581 PRINT H,K
590 GOSUB 6000
595 GOTO 510
600 REM Download To Movement File
610 OPEN "StpMtr.mov",W
620 INPUT Q
630 WRITE Q
640 IF Q=5 THEN GOTO 100
650 INPUT H,K
660 WRITE H;",";K
690 GOTO 620
810 GOTO 100
1219 REM
1419 REM
1910 RETURN
2050 DISPLAY F ;
2070 NEXT T
2190 RETURN
3090 F = F SHR 1
3100 NEXT T
3910 RETURN
4110 PRINT "Az ";
4130 PRINT " Alt ";
4150 PRINT ""
4910 RETURN
5110 PRINT "Az ";
5130 PRINT " Alt ";
5150 PRINT ""
5910 RETURN
6000 REM Find the Number of 1/8 Cycles
6110 N = H : IF N < 0 THEN N = 0 - N : REM N is Temporary
6120 O = K : IF O < 0 THEN O = 0 - O : REM O is Temporary
6130 P = N : IF O > P THEN P = O : REM # OF 1/8th Cycles
6140 N = H * $20000 / P : REM N = Az Increment
6150 O = K * $20000 / P : REM O = Alt Increment
6200 REM Drive the Steppers
6210 FOR U = 1 TO P - 1
6220 I = I + N : L = L + O
6230 GOSUB 1000
6240 REM GOSUB 4000
6241 REM GOSUB 5000
6250 NEXT U
6260 I = I + N : L = L + O
6270 REM GOSUB 4000
6271 REM GOSUB 5000
6300 REM Fix Final Position due to Divisional Rounding
6310 IF (I > 0) AND (N > 0) AND ((I & $00010000) > 0) THEN I = (I + $00010000) & $FFFE0000
6315 IF (I > 0) AND (N < 0) AND ((I & $00010000) > 0) THEN I = I & $FFFE0000
6320 IF (I < 0) AND (N > 0) AND ((I & $00010000) > 0) THEN I = (I + $00010000) & $FFFE0000
6325 IF (I < 0) AND (N < 0) AND ((I & $00010000) = 0) THEN I = I & $FFFE0000
6330 IF (L > 0) AND (O > 0) AND ((L & $00010000) > 0) THEN L = (L + $00010000) & $FFFE0000
6335 IF (L > 0) AND (O < 0) AND ((L & $00010000) > 0) THEN L = L & $FFFE0000
6340 IF (L < 0) AND (O > 0) AND ((L & $00010000) > 0) THEN L = (L + $00010000) & $FFFE0000
6345 IF (L < 0) AND (O < 0) AND ((I & $00010000) = 0) THEN L = L & $FFFE0000
6370 GOSUB 1000
6390 REM GOSUB 4000
6391 GOSUB 5000
6991 RETURN
RUN
This is an example of what can be downloaded into the move file.
The file can mix and match Absolute and Relative movements.
This file starts at 0,0 moves to 64,60 and back to 0,0.
I use TeraTerm terminal emulator in my PC.
This is used to comunicate with DongleBasic in the PropStick.
TeraTerm allows me to copy and paste into the PropStick through
the serial interface.
4 Download to File
1 Move Absolute
0,0
2 Move Relative
16,15
2 Move Relative
16,15
2 Move Relative
16,15
1 Move Absolute
64,60
1 Move Absolute
48,45
2 Move Relative
-16,-15
2 Move Relative
-16,-15
2 Move Relative
-16,-15
5 Done
NEW
10 PRINT "LOADING StpMtr01.bas":LOAD "StpMtr01.bas":RUN
SAVE "AUTOEXEC.BAS"
SAVE "StpMtr01.bas"
