no idea how a web server works
With a permanent broadband connection can you host a website on your home computer ? Is this in anyway connected to products like spinneret ? How do these things work ?
confused
confused
and it's free.
Once that's done, you need to "poke a hole" through your firewall to allow incoming requests and to set up your router to direct those requests to the box/board that hosts your server.
Yes, absolutely, there's a connection, since the Spinneret can operate as a web server. The "how" part is beyond the scope of a forum response, though. I would suggest reading the Spinneret documentation, along with the stickies in the Spinneret forum to get started. Then, when you have a specific question, post it there for additional help.
http://digitizor.com/2009/02/20/how-to-install-microsoft-iis-server-on-windows-7/
To reach it from the internet involves to get your IP address (could change sporatic)
Change your router to port 80 to local IP that your computer is on,
could also change unless set as static ip.
