Jumpy Ping Readings
Hi all!
I'm transitioning from a Stamp 2 to the prop and I'm having some problems with my ping sensor. It is jumpy. VERY jumpy. I am using the ping object in conjunction with serial terminal (both from Obex) and when I got everything up and running, the distances being spit out are all over the place. On seldom occasions and for no apparent reason the sensor seems to read decently, but without any apparent external influence, falls back into chaos.
I am using a Propeller Platform USB from gadget gangster with the power wired to +5v, and a 1k resistor from the data to the IO pin as shown in the Ping object file. I modified the ping demo to use the serial terminal instead of the LCD display. The board is powered by 4 fresh AA batteries.
For troubleshooting, I have tried:
1) completely removing the serial terminal portion of the code and replacing it with a 10 segment led bar read out with extremely simple code (still very jumpy).
2) testing the ping sensor on my old Stamp 2 setup (works perfectly).
3) rewriting the ping communication portion of the code in PASM (still very jumpy).
4) Checking and rechecking for proper voltages, shorts, etc (every seems good).
5) Using different IO ports
One thing I noticed different between the Stamp 2 and the Prop is that the sensor activity indicator LED turns off during the down time on the Stamp 2, but Prop its on constantly. I suspect this may point towards the problem.
Any help would be much appreciated!
-Iratenate
-Iratenate
Everything is working fine. Thanks!
-Iratenate
