Please assist, cannot find reason for high pin 23 — Parallax Forums
KarmanKarman Posts: 4
edited 2011-02-28 07:57 in Propeller 1
Hi
Please can someone explain why below code make pin23 go high .... If i move the order of the Var's around, the pin sometimes go high, other times not..
I suspect that 1 variable is leaking accross to other, but cannot seem to figure out what... 6 hrs later.. i'm stump
any assistance much apprecaited
Liaan
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000 ' 5 MHz cyrstal (sys clock = 80 MHz)
' Set this to the pins you have connected to the 74HC595's
in = 1
T_buttons = 0
SR_CLOCK = 1
SR_LATCH = 2
SR_DATA = 3
button0 = 7
delay1 = 1 '1second
delay10 = 10 '10seconds
var
long temp
long delay
word out
long x
long butcnt
long abuttonState[T_buttons]
long buttonDelay[T_buttons]
long button_press[T_buttons]
long button_double[T_buttons]
long button_now[T_buttons]
long timeout
long button_last_down[T_buttons]
long debounce_time_ref[T_buttons]
PUB Main | i, button,led_state
dira[7]~ ' set buttons as in
dira[16..23]~~ ' set led's as out
abuttonState[0] := 0
delay := clkfreq * delay1 '1s
' temp := delay + CNT
repeat
doubleclick
Pub DoubleClick | butcnt2, xx, but_time ,i ,but[T_buttons],debounce_delay
debounce_delay := clkfreq/1000 * 300 '30ms
repeat i from 0 to T_buttons ' check all 10 buttons
' but := ina[button0]
if but == in
debounce_time_ref := debounce_delay + CNT
ButtonDelay++
else
buttondelay--
outa[23] := abuttonState[0]
  • RaymanRayman Posts: 16,457
    edited 2011-02-27 14:47
    Please post the code with the "wrap [code]" options, so we can see the indentation.
    Or, just attach the spin file.
    One thing I see right away is that you don't initialize OUTA...
    Right before your DIRA statement, you might try a OUTA:=0
    edited 2011-02-27 16:34
    All your arrays based on T_buttons have zero length. Highly unlikely that's what you want (an array is declared with the number of elements not some index magic). So since buttonDelay[0] is now the same as abuttonState[0] you'll get a 1 in bit 23 (buttonDelay[0] is initially 0, ++/-- will toggle its bit 0). Once you adjusted your array sizes make sure you keep the loop Finish parameter in sync.
    edited 2011-02-27 17:57
    good catch, that definitely looks like a problem...
  • KarmanKarman Posts: 4
    edited 2011-02-27 23:19
    thanks very much for responce..
    I should not post questions at 12:30 am... I posted one of the many versions i tried to troubleshoot the same issue.
    the orginal array size was 10. I created the variable array size to try and troubleshoot the problem.
    When i remove the line: ButtonDelay++, pin28 don't go high. when i move long temp, and long delay to the bottom of var list., the pin28 randomly goes up / down.(seems to be linked by "cnt"offset)
    at this time, my only guess is that buttondelay array is "leaking" into abuttonstate when delay value gets to big.
    of course, i'm very new to spin, so can be on completely wrong path
    L:
    in = 1
    T_buttons = 10
    SR_CLOCK = 1
    SR_LATCH = 2
    SR_DATA = 3
    button0 = 7
    delay1 = 1 '1second
    var
    long temp
    long delay
    word out
    long x
    long butcnt
    long timeout
    repeat
    doubleclick
      ' but[i] := ina[button0]
        if but[i] == in
          debounce_time_ref[i] := debounce_delay + CNT
          ButtonDelay[i]++
        else
          buttondelay[i]--
    edited 2011-02-27 23:24
    O yes,
    forgot to add, if i debug.dec(abuttonState[0]) it increments from 0-255 and then back to 0 the whole time. (debug code not added in above post as i removed it thinking maybe causing the problem)
    L:
    edited 2011-02-27 23:26
    kuroneko wrote:
    ... make sure you keep the loop Finish parameter in sync.
    If an array is defined as long data[N] then the available indices are 0..N-1 which means your loop should run from 0..T_buttons-1.
    repeat i from 0 to T_buttons[COLOR="red"]-1[/COLOR] ' check all 10 buttons
        if but[i] == in
          ButtonDelay[i]++
        else
          buttondelay[i]--
    If that doesn't solve the problem we simply keep looking. Note that local variables are not cleared to zero meaning your if but == in may be a bit of a gamble.
    Thanks all!!
    seems to be the -1 that caused all the #%*#$*
    lesson learned
    Will try post my final code when i eventually get my logic fixed
    cheers
    L:
