Quad or hexcopter kit
I know there are threads on the quadcopter in the forum, but I am wondering if anyone has a "ready to go kit" that uses a propeller chip in a "copter". I am vice-president of a small non-profit community access TV station in Woodland, Ca. We may be in the market for a quad or hexacopter to use in some projects that are coming up...one involves helping wounded vets coming back from the middle east to readjust and videoing them doing sports with their artifical limbs. We would use the quadcopter to get aerial shots. Anyway, after hearing so many good things about how the propeller chip is being used in quadcopters, I was wondering if anyone has actually solved all the problems and has a kit. I need one that could lift a small digital camera for a 2-4 minute video clip. It would be nice if it could send real-time sampling back to a ground station. I would also be nice if we could swivel the camera from the ground. I know some German companies have things like this already, but I want to give the propeller chip as well as Parallax a chance to shine. If someone is currently doing something along these lines and would be done prototyping by June 2011, give me an email or post a reply. I am a beginner robotic enthusiast and would not mind helping in the process, but I would have to have a finished device by the above mentioned date.
There are kits available but I think they only come in ARM or AVR variants, though.
This week I ordered one of the Hoverfly boards at http://www.hoverflytech.com/. Their design uses a Propeller and it's configurable instead of open-source. Their product is mostly used for aerial photography. They don't offer a frame so I'll be building my own. I initially wanted to program my own Propeller to interface with gyros, accelerometers, ESCs, and receivers until the reality struck - I don't have time to go that route.
Since you're in Woodland - about 45 minutes away - how about if you come over to Parallax after my Hoverfly board arrives and we'll take a look together. This board can fly larger quad/hex/octo copter designs. Their documentation is here: http://www.hoverflytech.com/uploads/HoverflyProUsersGuideV1_2.pdf
My board should arrive in about a week if you want to check it out.
Parallax Inc.
I expect to have a pcb available in less than 1 month to specifically handle the Radio receiver inputs and esc outputs on an smt pcb 1.1x2.1" and a piggyback pcb for the sensors. However, big advances have been made using the gyro on the Wii Motion Plus, which I also have for investigating.
I will PM you and Ken offline further.
Fred
When you have a pcb I am interested please send me an email. I am to buy one.
Have a GAUI 330 quad.
Last year , tried also to write a quad program for the propeller : it works well for getting the DX8 radio receiver inputs and sending commands to Turnigy esc , reading gyros and accelerometers.
But I am not good enough to write a mixer for the commands and a sort off PID controller like the Aeroquad one.
Cats92
I guess it would be super hard even if take off and landings were done by the radio operator.
mickal: I would expect it would be far simpler to control in flight than a quadcopter. Even for takeoff and landing, it could be programmed to remain level across the wings.
Ps. Ive also purchased 3 hydrlic units to make a flight sim and have sketched up a couple of designs Ive got a great workshed on the folks farm and enjoy metal fab but that idea will be a few months off.
Honestly, it doesn't take long - you might even be able to find a local hobby store that has an R/C flight simulator for sale with a "try before you buy" kiosk. Spend 15 minutes on that - you'll probably crash a few dozen times without it costing you a cent, and it'll help you get past the initial hump. Practice take-off, landing, and flying simple patterns, like a figure 8 in front of you.
ps. I have been playing with the nokia display again this morning. I was trying to modify other code but your driver was plug and play
BTW I will be in Brisvegas next Monday but no spare time.
My flying/crashing was done years ago. I could take off and make a few loops of the field, but always got into trouble before any landing attempt began. But the copters will allow me to fly in the yard, etc. I have a great set of water out the back too, once I am sure I will not crash it - cannot waterproof the motors, etc.
I have some blades for the motors, but no corresponding counter rotating ones. I would much rather use these than place 2 motors on angles. HobbyKing never seems to have both normal and counter rotationg in stock at the same time (at least when I look). Any other cheap (shipping is the biggest cost) props (as in propellor blades, not chips)?
http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=151&curPage=3&v=&sortlist=&LiPoConfig=
They seem to have some in stock at the moment. So far I prefer the 3-blade over two-blade as the vibrations from the air hitting the motor support arms are at a higher frequency so they're a little easier to filter out.
Counter rotating props are notoriously hard to find, because they're not used all that often. Dragonfly (http://www.rctoys.com/) probably has some too, but I doubt they're cheap.
Then there are hobbykings own brand http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=295&curPage=1&sortlist=&LiPoConfig=&qty=30 Which are also inexpensive. I need a min of 5 channel to use the flaps as well. The HK $59 has 7 channels. The customer comments seem to have been removed so im not sure. Ill see if they respond to emails.
sorry custommer reviws are there. I just looed at a $25 HK unit 6 channel. customers seem pleased. 8 or 9 channel would be nice but at half the price its probably ok for me.
I would value any of your opinions.
That said, if you plan on using it for other r/c stuff, or plan to be doing this a while, spending a bit of extra money up front is a good idea. The radio is the "interface" to your planes. Buying a cheap one will impact how well they fly, how "connected" you feel, and so on. It's like buying a great car and then putting garbage tires on it.
