Penguin English
Penguin English REV B
This program enables Penguin robot to recite English letters
including all consonants and vowels by displaying the results on
the 7-segment display. The Debug screen will show the letter,
decimal, hex and binary values!
' Title Penguin B English ' Code Name penguinb_english1.2.bpx ' Author Humanoido ' Purpose Penguin B Recites English Letters ' Version 1.2 ' Begin 10 February 2010 ' Update 23 February 2011, 23 March 2010 ' Hardware Parallax Stock Penguin REV B BOARD ' Contact penguin(dot)robot(@)yahoo(dot)com ' ' DIRECTORY ' --------- ' PENGUIN RESOURCES ' OVERVIEW ' PENGUIN ENGLISH 101 ' THEORY ' THE PROGRAM ' MAKING A FONT & CONVERSION CHART ' NUMBERS ' PENGUIN ENGLISH FONT ' PROGRAMMING ' REVISION BOARDS ' BOARD DISPLAY CAPABILITIES ' DRIVING A SEGMENT FONT ' CREATING LETTERS & CHARACTERS ' FONT LIMITATIONS ' PENGUIN FONT DERIVATIONS ' MATH & SPECIAL CHARACTERS ' LED SEGMENTS IDENTIFICATION CHART ' SEGMENT DISPLAY ILLUSTRATION ' SEGMENT POSITIONING $ BYTE ARRANGEMENT ' PROGRAMMING FORM, DP, BIT NOTATION ' ' ' OVERVIEW ' ------------ ' About a year ago, I contacted Ken Gracey of Parallax and suggested ' upgrades to Penguin - mainly to gain an extra port and enable greater ' display capability, using a shift register. This small integrated ' circuit chip is most noted for expanding outputs. It was an idea ' well received! ' ' ' THEORY ' ------ ' The idea was to control the seven segment display with just three lines ' instead of four, using the 74HC595 "serial in parallel out" shift register. ' I'm happy to say the idea has come to frution. The 74HC595 design converts ' a synchronous serial data stream to eight parallel outputs, namely seven ' segments and one decimal point. ' ' ' THE PROGRAM ' ----------- ' The program has all the tools necessary to display English letters. ' It calculates and displays the ascii, decimal, hex, and binary in ' chart form on the Debug screen. ' ' This is handy if you prefer to work with decimals instead ' of binary numbers, etc. The code comments simplify the method for making ' additional characters using the Binary number approach. ' ' ' MAKING A FONT & CONVERSION CHART ' -------------------------------- ' The code is written so a Font and Conversion Chart can be created. Just ' run the program and push pause when it completes the Z line. Now use your ' favorite screen capture program and snap a photo of the chart on the ' Debug screen. ' ' ' NUMBERS ' ------- ' Numbers are inclued with this code. Remove the REMs if you want to display ' all the numbers and the decimal point. See other Humanoido programs ' for Penguin to show Penguin Font, create text numbers, special English ' punctuation, math and graphic characters. ' ' ' PENGUIN ENGLISH FONT ' -------------------- ' To create English text letters, first a Penguin font is created. ' The font style best represents letters on the 7-segment display. ' To minimize redundancy and maximize recognition, there is a mix of ' case. The Penguin font is not upper or lower case specific. ' ' ' PROGRAMMING ' ----------- ' The synchronous serial data has components to program, mainly the serial ' data and the serial clock. The SHIFOUT command is chosen to handle these ' details and write data to the synchronous chip. After the shifting process, ' the data must be latched to the outputs by momentarily pulsing the Latch ' control line. This will stabilize the outputs as new data is shifted in, ' and is accomplished with a PULSOUT statement. Shiftout is LSB least ' significant bit first. ' ' ' REVISION BOARDS ' --------------- ' Revison B boards use a 74HC595 shift register to control the segment display. ' This requires only three pins instead of four, and gives Penguin the use of ' an extra port (located behind the display). ' ' ' BOARD DISPLAY CAPABILITIES ' -------------------------- ' Rev A boards could only display numbers 0 through 9 and five graphic characters. ' The DP was dead. ' Rev B boards enable the display of numbers 0 through 9, the entire English ' alphabet with a special font, and dozens of graphics combinations and the DP ' is alive. Using this program, it's now possible for Penguin to output text ' sentences on the segment display for "talk." ' ' ' DERIVING A SEGMENT FONT ' ----------------------- ' The easy way to create fonts is to make a segment font that fits Pengin's ' segment display. To create English text letters, first a Penguin font is ' created. The font style best represents letters on the 7-segment display. ' To minimize redundancy and maximize recognition, there is a mix of ' case. The Penguin font is not case sensitive. ' ' ' CREATING LETTERS & CHARACTERS ' ----------------------------- ' Letters & characters are created with a binary lookup table. Copy the form ' and change the 0s into 1s for the segments to turn off. The code is sent ' to the 74HC595 shift register and sets the display segments. The program is ' written in binary as it can correspond readily to a visual representation.
