Penguin Build Question
Hi All,
Just got my penguin robots and I have a question... Which servos get hooked up to which Jumper port on the battery pack? Unless I missed something, there's no indication on the battery pack/PCB (or schematics) which port is J1/Stride or J2/Tilt. Looking straight down at the battery pack, the USB connector is on the bottom and the ribbon cable is on the top, is J1 on the left and J2 on the right?
Thanks in advance.
Thanks in advance.
Penguin Robot Servo Connections
Keep track of Penguin servo connections for tilt and stride
Referring to the Penguin Documentation
As seen in this Photo, J1 is on the left and J2 is on the right.
Jumpers should be labeled on the black board in white
lettering. This applies to both A and B Penguins.
Here you can see J1 and J2 labeled on the Penguin A. It may be difficult to see which servo cable runs where... When running tests, you may want to remove a connector. Don't! Simply plug in one pin on the end of the connector. That way, the connectors and their respective plugs, and the directions of the plugs will never become mixed up.
Well, everything is working well now, fully built and calibrated. I was a little worried at first because one of his feet was twisted upwards as the tilt servo horn was not perfectly perpendicular, but I was able to compensate for that in the calibration program.
Next up, performing the rework on the battery board...
Thanks.
