BASIC Stamp behaving strangely...
Hi everyone. I've been experiencing weird errors when programming my BS2 on a USB BOE carrier board since about a week. (mounted on a boe-bot)
Most of the time, the BS Editor just failed to locate the stamp, but now, the editor come out with errors such as ''Can not program version vF.F of the BASIC Stamp 2. Contact Parallax Inc. for updated software''.
I've been on the same program for nearly a month and I just don't understand what is going on...
What I have tried already:
1. Change batteries
2. Use a new 9 volts battery instead of the BOE-Bot AA pack (Servos turned off, off course...)
3. Change batteries again (these Duracells does suck...)
4. Run another simple program (First prog in WAM)
5. Shake the USB cable to see if it's broken
6. Change the cable just to be sure while using another USB port
7. Shout at it
8. Ask for help on the Parallax forums
It's probably a stupid problem, but I really can't find it!
So... Help please?
Ignorance is never better than knowledge.
-Enrico Fermi
1. Change batteries
7. Shout at it
So... Help please?
-Enrico Fermi
What?:
O.S. are you using?
StampEditor Ver?
Stamp?
code?
O.S: Win7 Ultimate x64
StampEditor: V2.5
Stamp: Standard BS2 Rev J
Code: All kind of. I tried using example codes from WAM, but still doesn't work.
When I try to upload my code to the BS2 , the system fail 1/3 of time to find it (while it's on), and the other 2/3 of time, the editor just pop the error ''Can not program version vF.F of the BASIC Stamp 2. Contact Parallax Inc. for updated software''. I tested it for brownouts, but everything is normal. I really don't get it. I just hope my BS is not broken, even if it is unlikely...
EDIT: Hmmm? Well, that is weird. I run the program on both my desktop and my laptop while they show the same error. After restarting the editor on both, I still get the error on the laptop but everything is working again on the desktop... This is starting to make me pull my hair off!
I'm contacting the Parallax tech support... But any of you guys ever heard of such a problem?
The next time your COM ports hang-up, Open the Task Manager and look at what app.s are running in the back round.
I would look for printer/camera USB app.s like Lexmark,HP,Epperson,etc.
