trying to figure a few things out in spin
Hey guys, I'm new to Spin and the Propeller all together. I'm used to programming in C, C#, and Java and so there are a few things in Spin that I haven't been able to figure out.
1. Is there a way to have a method return a value or an object? I've seen people just make global variables and then have the methods just write to it. But I'm trying to make a linked list object and want to be able to add and retreave data.
2.
3. Just any tips or tricks you guys have found, a website that has all the libraries and it's methods....
Thanks guys, I've very excited with the thought of multiple cogs.
2.
Pub checkping | leftdistance, rightdistanceIn a tutorial on Gadgetganster they have this, but leftdistance, and rightdistance are never instantiated as a variable. So is it instantiating it right now and what variable type is it.
Also. Just type return.
Everything in SPIN works like you expect in C expect for a few cases. The ">=" and "<=" operators in SPIN are not the same as they are in C. (They assign in spin... you have todo "=>" "=<" instead).
Sure it's possible to return a value, the following forms are functionally equivalent AFAIK:
As an argument to "return":
By assigning the default internal variable "result":
Using a named return variable:
Is not normally possible to return an object, but people have figured out a few tricks to implement this.
that IS the instantiation of leftdistance and rightdistance, they are local variables to the function "checkping", and the type is always long integer.
Tips and tricks are just too many to list... you could start with these:
http://propeller.wikispaces.com/
http://www.rayslogic.com/propeller/Programming/Programming.htm
http://ucontroller.com/Propeller%20Protoboard%20Designs%20for%20the%20Beginner.pdf
Usually the newest stuff is here on the forum, just search or ask right away.
Regards
Alessandro
A There is the exception that - if running from EEPROM - you could modify global variables in the EEPROM image which effectively changes their initial value.
welcome to propeller world!
I think when you talk about C, C# and Java you also talk about machines having a lot of memory and even more swap-space. All those languages have memory management build in, dynamic object generation and so on.
In propeller-world we talk about a microcontroller with very limited resources. I know there are some effords in making the propeller a general purpose computer and make programming the prop as "easy" as for other computers.
But I think you should brake free from this. Dynamic data handling needs additional memory for managing the dynamic data and functions which take care of the available RAM. So in the end this type of programming eats up RAM and RUNTIME. Not a problem for a PC but it leads to problems on a uC very fast.
In my opinion the most effective way of programming the prop is to avoid those PC concepts.
Why do you need a linked list?
The line "Pub checkping | leftdistance, rightdistance" defines checkping as a method with no parameters. leftdistance and rightdistance are long values that are created on the stack. There is also an implicit stack variable name "result", which is initialized to zero and can be used to return a value if an explicit "return value" is not done. In C it would look something like this.
I can tell I'll have to tweak how I attack a program but this should be very fun. Thanks again for all your help.
