Harsh conditions, can it be done?
The application I'm evaluating must have the circuits shielded in a steel can to protect them from magnetic fields. For the same reason communication (out only) must be optical/serial. Here is the real kicker. I need to pot and balance the module to withstand up to 10,000 RPM. I know the Air Force has done a lot of work to perfect gun tube launched satellite electronics but I don't know how much info like that is available from the private sector. The electronics/software is no challenge at all but my processor of choice would be the Propeller due to the 3.3 voltage required. A potting compound I use to use from Masterbond was good to 10,000 PSI compressive (pricey though). The assembly should not really see any shock loads on top of the static centrifugal force field.
and the magnitude of a small voltage signal.
I did some magnetic testing for a 320MB/s ultra-320 SCSI system. It was in a 6mm-thick aluminium box. Even at levels of magnetic field equivalent to a ship being degaussed there was no perceptible effect.
Good luck,
T o n y
