How do I safely share a single LCD display between two stamps?
I would like to share a Parallax 2X16 LCD (Back-lit) Display with a BS2 and a BSP40 at the same time.
My concern is how to protect the hardware from any potential damage.
Can I simply tie the data- pins together? Do I need a resistor in series? Should the pins perhaps be pulled high or low?
Perhaps this is a no-brainer to many, but I think it is wise to check first.
Thanks!
Thanks!
Because you could end up with strange outputs....
My concerns are purely wiring-up, at this time.
Thanks!
Seems to me, I may want to, at least, pull each pin high using a 4.7K resistor so as be an open drain. This protects the pin and prevent damage if there was a short to ground? And perhaps use a 220 ohm in series on each data line to protect the pins from each other?
I just want to prevent damage, and think it's worth the asking.
Thanks!
That is exactly what i needed to know...I see the 10K and it is pulled to ground.
Awesome,
Thanks!
