EmbeddedBASIC
Humanoido
Does anyone have a copy of Embedded BASIC (before the tiny font TV driver was added)?
I'm trying to find a version with bigger characters that can be used with the 320 x 240 pixel Parallax TV.
Thanks for your interest. Here is a 32 column version of Embedded Basic.
Try "COLOR 15" or "COLOR 240" for a black/white display.
Let me know how it works for ya...
This is actually version 0.13 with a few changes:
Changed PEEKB to PEEK and POKEB to POKE
Added FREE variable (returns free program space)
Added SCREEN variable (returns address of screen memory)
P.S. The binary is for the demo board.
Bean
FREE and SCREEN not function for me.
UNKNOW COMMAND IN LINE 0
Other things function correctly on PropCade
Have other Question.
Why PS2Keyboard use HUB to hold KeyKodes IF COG have place to have them in COG --- Give more place in HUB
I suggest looking at FemtoBASIC Version 3.007 which looks perfect. It has 40 characters per line, the characters appear much larger (more vertical height) with an easy to read font on the 320x240 pixel screen. It has white characters on a normal no-color background with no smearing of text. If this helps to know which driver is used, when I open up the program, it has
dsp : "tv_wtext" ' TV Windowed Text Driver ' TV
I should also mention the color version FemtoBASIC 2.004 font appears too small on the screen.
Can you adapt the FemtoBASIC screen driver and font and make it work with Embedded BASIC?
Thank you sincerely.
http://www.ahleman.com/Props/ElectriClerk.html
BTW: Highly recommended tech dystopia.
at post number 320
The core problem you've got is just lack of sufficient pixels per arc degree in your field of natural vision. I would recommend you use a moderate set of reading glasses over one of those lenses. They do not have very good distant optical characteristics, really only able to perform at fraction of inch range from the source image. A lens with a longer focal length would be good, but expensive to get a large one. The other alternative is to simply put a lens closer to your eye, to use the shorter focal length to best advantage, keeping optical distortion to a minimum.
...or get a slightly larger display. One that has even 1/3 more area, even with the same pixels, would deliver a considerable improvement to you, though the larger ones often offer more pixels anyway.
With Embedded BASIC, the font is displayed with artifacts as you can see in the photos. This is the issue here, not human vision. The font is simply smearing and has problems rendering. The one version, as mentioned, the font is so small it becomes unreadable.
The real problem is the excellent designers of the TV drivers don't have the Parallax 3.5-inch monitor for testing. Well, you can run it past me and I'll test it. I'd say just use the Mike Green TV driver in the version mentioned and everything will be tack sharp.
The spectrum driver, and my current driver do "real" color phase shifting for a proper signal. The Parallax reference driver does this too. On higher resolution devices, that renders better than the simple non-color phase shifting driver you are talking about. AiGeneric does the same simple signal, as do some of my older drivers for TV.
Problem with those, is one can't really do higher character densities, and in fact, 40 columns can be at issue with more color combination than not.
This driver has a non-interlaced mode that might help some with that. Depending on what your display does with a full interlaced signal, that might be the better option too.
There isn't a good way to resolve those issues, other than to plug in various drivers for displays. No one size fits all is possible. IMHO, it would be difficult, if not impossible to pack the various signal options into a single COG too.
That's the real problem. Simple, low resolution displays perform differently on signals than higher resolution ones do. And I didn't say your vision was bad, only that you don't have enough detail per arc angle of your field of vision with that display, and that display not having enough pixels to really display a higher quality signal.
The lower quality signal output from the older drivers would work well on that display, but rather poorly on higher resolution ones.
I don't know that there is a good answer, other than to tear into the BASIC and offer up options for various drivers. The issue there is the memory foot-print and display options. What will work well on that little TV won't really work well on larger devices and or higher resolutions.
The next question is what will it take to accomplish this?
