n00b with a datalogger
Greetings All,
I'm currently having absolutely no luck with trying to get an SD card reader attached to my Prop (Stingray board). I'm using the SD3 Object code with most of the additional peripherals disabled, see code below.
When running the Demo, all I get is 'Disk IO Error'
I'm using Parallax SD Card adapter #32312 for the micro SD card adapter, currently attached to pins 16-20 as per the code above.
I've also managed to kill a USB datalogger with a firmware upgrade, so thought SD might be a little safer.
Would appreciate any tips on obvious things I might have missed.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 _leftChannelVolume = 32 _rightChannelVolume = 32 _baudRateSpeed = 57600 '250_000 _newLineCharacter = 13 _clearScreenCharacter = 16 _homeCursorCharacter = 1 _receiverPin = 31 _transmitterPin = 30 _RTC_DAT = -1 ' -1 ifnot installed. _RTC_CLK = -1 ' -1 ifnot installed. _VGA_Enabled = false _VGA_PinGroup = 2 _VGA_H_Res = 160 _VGA_V_Res = 120 _VGA_BG_Color = bmp#black _VGA_FG_Color = bmp#green _leftChannelAudioPin = -1 ' -1 ifnot installed. _rightChannelAudioPin = -1 ' -1 ifnot installed. _leftMicFeedBackPin = -1 ' -1 ifnot installed. _leftMicInputPin = -1 ' -1 ifnot installed. _rightMicFeedBackPin = -1 ' -1 ifnot installed. _rightMicInputPin = -1 ' -1 ifnot installed. _SD_DO = 16 _SD_CLK = 17 _SD_DI = 18 _SD_CS = 19 _SD_WP = -1 ' -1 ifnot installed. _SD_CD = 20 ' -1 ifnot installed.
