USB and RS232
Hugh
I have a Prop-based box that used to drive an ELM327-based OBD reader, logging engine parameters of my car, etc.. This used FullDuplexSerial to drive an RS232 connection and everything was fine until I broke the ELM327 OBD unit - all possible replacements have a USB connector for connection to a laptop. (Progress, eh?!)
If I were feeling brave, is there any way that I could connect the USB connector from the OBD box into a prop-plug and achieve a connection that way or is there a fundamental flaw in this plan (such as power coming from the USB plug)?
If not, any other ideas please?
Hugh
Hugh
I don't know how skilled you are. I'd guess that most OBD devices also use a USB 2 serial converter. So, if you open the box it could be possible to identify the chip and find the serial connection to the OBD controller. Here you could connect the propeller after some small PCB modifications ;o)
That was my cunning plan. Having bought a couple of ELM327 devices on eBay they both turned out to be PIC-based clones. I may soon know how completely they have been cloned (an abhorrent abuse of intellectual property).
