serial communication with the propeller servo controller USB (PSCU) - how to?
Hi
I'm trying to communicate with the STAMP on a BOE through a serial line to the propeller servo controller USB #28830. ( I am using the same program that I used for the older servo controller (no longer available)). Although the program is identical to the one in the write up for #28830, I can't seem to control the servo motors that are connect to the #28830. The green light flashes, but nothing. Has anyone encountered this problem? (I've been trying for some days, but no luck. tech support at Parallax doesn't seem to be able to help.) I would be so grateful if anyone can tell me what I'm doing wrong. What am I missing here?
Allan
Allan
Connections; power, servo, and serial?
Baud?
What kind of STAMP?
Source code?
PSC Jumper is set to 0-15 or 16-32?
Does the old PSC still work?
Have you tried connection to a PC and issuing a version command using PCSI?
The program looks like this:
ch VAR Byte
pw VAR Word
ra VAR Byte
Sdat CON 15
baud CON 396
ra = 7
ch = 11
DO
pw = 1100
SEROUT Sdat, Baud+$8000,["!SC", ch, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
PAUSE 1000
pw = 300
PAUSE 1000
LOOP
END
I'm wondering if the green LED that flashes means that it's communicating, because the LED does.
This is with a stamp 2 and with stamp2sx on BOE. The program and everything works fine with the older servo controller.
Is the 28830 not compatible with the BOE serial protocol, even though it's advertised as so?
(by the way, this is my first posting ever on any board, so pardon my inexperience. I just want to get this to work.)
The code can be found in the PSCU manual.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/28830-PropServoControllerUSB-v1.0.pdf
If that does not work, then you'll need to phone tech support.
