Sensing direction and angle with no encoder
I have a stepper and no encoder to drive a 10 teeth gear (36°/tooth). Since the gear (and motor) can be moved by external forces under certain conditions I would like to sense this condition.
I don't have encoders for neither the stepper nor the gear and no space to place them
I was planning to use 2 Melexis cam sensors (MLX 90217) in a 1/2 tooth offset (i.e One cam sensor points at the peak of the tooth and the other points at the valley)
I'm assuming I could get get a fairly good resolution (18° is ok for me) and direction sensing with this setup.
Has anyone done this?
Any other ideas I could use?
Thanks in advance
Alex
Thanks in advance
Alex
Dave
Lots of forum input there as well as clever code examples.
