Problem with gas sensors. How many calibrations !! Please help.
I am using the CO (Carbon Monoxide) Gas Sensor Module (code 27931)
My problem is that each time I turn off the sensor module because I need
to replace batteries (for example) I need to calibrate it again.
I am tired of calibrate it each time . I don't know if all CO modules from Parallax have the same problem.
Do you know ?
Thanks, Joe
Do you know ?
Thanks, Joe
If its not in eeprom,Or in some nonvolatile storage, It will be lost every time you cycle power on the Stamp.
These modules don't send data. The module sent a 0 or a 1 when gas
is near to the set point.
Please , could you confirm?
Thanks, Joe
The carbon DIOXIDE sensor we're using in our project outputs data as millivolts, somewhere in the range of 2500 mV:
http://forums.parallax.com/showthread.php?122688-ARLISS-Team-NH/page38 (look at the diagrams)
You have to convert millivolts to parts per million of CO, or CO2. Read the lengthy discussion on our forum and you'll get a better idea. I suggest you read in and around page 36
> 40 on our forum pages. Some excellent graphs and explanations are included. We had lots of help from others.
http://forums.parallax.com/showthread.php?122688-ARLISS-Team-NH/page36
Mark - ARLISS Team New Hampshire
